01-23-2015, 11:27 AM | #43 |
Drives: 14 1LE Join Date: Mar 2013
Thought I would share this: in concern for oil temps while tracking, I sent a oil sample to be analyzed for heat damage and the general condition of the oil. This sample included 5 track days with oil temps around 280-290 and 3300 miles on the oil. The results showed that the oil had no signs of heat damage and maintained its viscosity. Additives package in the oil were still at good levels providing adequate anti-wear protection.
Thoughts/discussion...
LMS Engineering
01-23-2015, 11:43 AM | #44 |
Drives: Camaro Justice Join Date: Jun 2007
We have a 4.5 gallon dry sump system with a cooler installed on SSsoon's LS7 Camaro. Temps in Virginia have been low 50s high 40s. We are still adjusting the tune, and have done nothing but street driving. The highest temp reading we have to date is 120 degrees on our gauge. The factory gauge has not moved. More details ssssoon.
Note: Oil is 15/50 Mobil 1 Last edited by JusticePete; 01-23-2015 at 11:54 AM. |
01-23-2015, 11:49 AM | #45 | |
Cadillac Service Manager
Drives: 2014 Camaro 1SS, 1LE, NPP, RECAROS Join Date: Jun 2013
What oil are you using?
01-23-2015, 12:13 PM | #46 |
LMS Engineering
01-23-2015, 12:48 PM | #47 |
Drives: '16 C7 Z51 Join Date: May 2012
This is pretty good news, especially considering all the bad rep given to Mobil 1 5W-30. I'm using 0W-40 for hopefully a bit better protection/lubrication at higher temps, which supposedly has better shear resistance with its revised formulation.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
01-23-2015, 01:04 PM | #48 | |
Wondering if GM wasn't seeing any problems with oil condition and decided against a proper oil cooler?
LMS Engineering
01-23-2015, 01:31 PM | #49 | |
Mobil 1 0W-40 has been the factory fill for Euro-market Corvettes for a long time now (including C6, which uses our engine family), so I am confident it would work well with our engines.
01-23-2015, 05:53 PM | #50 | |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
Thanks.
01-23-2015, 08:09 PM | #51 |
01-23-2015, 08:14 PM | #52 |
Drives: 2022 SS 1LE Join Date: Jul 2013
Guys,
Just wanted to give you a heads up that I ran my car at the track last weekend with the new dual oil coolers, mounted to either side of the radiator, with custom shrouds to suck cool air through them. The results: Before the oil cooler upgrade: 290 F oil temp in 3 laps, then had to back off After the oil cooler upgrade: 220 F max oil temp, while running hard the entire weekend! This set up kicks ass. I'll write it up when I get some time. BTW, I'm running Shaeffer 5W/50.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb 1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697 Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086 |
01-23-2015, 08:36 PM | #53 | |
01-23-2015, 08:38 PM | #54 |
I should also add, if you're reading temps in the sump (not in return line from the cooler), I think you can very safely switch back to Mobil1 5W-30 : )
01-23-2015, 08:49 PM | #55 |
Thanks man. Coolant stays at about 205 F all day. I'm not sure on the thermostat.
Oil temp is read at a sandwich plate above the oil filter.
01-23-2015, 09:36 PM | #56 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
crush,
how'd you plumb the coolers and where is your temp sender? my temp results are similar to yours I've not run a track weekend with the cooler yet, will do that on the 7th, but I've noticed that the temp normally stays around 210F. when driving "spiritedly" the temp keeps under the 230 mark on my gauge. my in and out is from the ports just above the stock filter, my temp sender is on the "hot" side, before the oil goes through the cooler.
