Old 03-04-2017, 12:14 AM   #1
Abdul_11
Abdul_11's Avatar
Drives: Camaro SS
Squash fuel system question
I have a squash return system with 8 supply and 6 return, my question is the 6 return enough to make +1kwhp or not?
2012 LS3, ERL 416ci, Squash dual fuel system, procharger F1A cog race kit.
Abdul_11 is offline   Reply With Quote
Old 03-04-2017, 01:19 AM   #2
hou30guy
Drives: 2011 convertible 2ss/rs
Yes
hou30guy is offline   Reply With Quote
Old 03-07-2017, 10:59 AM   #3
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
I went with 8, maybe even 10. Cannot fully remember. 6 was choking the build. 418 ls3 with twins and 4l80e.
2011 Victory Red 22/RS
Forged 418 Ls3 from Texas Speed, LSX heads from Texas Speed, Tick Turbo cam, Jakes/PCM/Billet 4l80e, 3200 Stall converter from Circle D, DSS 750 hp axles, DSS aluminum driveshaft, stock 3.23 gears, TSW Wheels Front 20x10 Rear 20x11.5, Fabberage Twin Turbo Supercharger Killer kit with Upgraded Turbos, Squash Dual fuel pump, Full BMR Suspension/bushings, Holly High Rise intake manifold, ID1300 Injectors, Megan Coilovers, PCM of NC plug and play trans kit. HP/TQ TBA
DaFisch is offline   Reply With Quote
Old 03-07-2017, 11:04 PM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
-6 will feed 1kwhp reliably. It is about pressure with fuel injection, not volume. Carburetors need volume because they don't have the pressure.
I used a stock feed line to a short 8AN line that Y'ed to 6AN to reach rail and also used a 6AN return line and fed over 1kwhp with zero issues with Squash. I'm currently running 6AN feed and using the factory feed as a return. I only changed things because I switched over to the Squash E85 pumps (had regular gas before) and figured while I was in there, I'd change the lines to the Aeroquip startlite Squash offers.
I believe it was Dave Steck who said they haven't reached the limits of 3/8 fuel line (comparable to 6AN) yet on GTRs.
http://www.corvetteforum.com/forums/...line-size.html
http://fuelab.com/fuel-line-size-vs-pressure-drop/
http://board.moparts.org/ubbthreads/...ne-handle.html
