08-29-2017, 01:58 PM | #1 |
Drives: 2016 2ss Join Date: Jun 2016
Removal of third brake light
I looked at the thread on this buy there was 4000 posts so i figured id cut to the chase. Can some summarize the best way to install the new black tinted gm third brakelight?
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in. |
08-29-2017, 02:17 PM | #2 | |
Drives: 2017 Camaro 2SS, Black/Red Join Date: Mar 2017
Remove dedklid insulation/liner.
Pull out on the old light (use non mar tool to leverage/pull up, perhaps some tape to protect surroundings). Disconnect connector. Clean off old two sided tape adhesive. Install new one. Watch Lethal's video, just ignore all of his small misteps. Learn from his lessons. You do not need to remove or adjust the metal screws/clips. It's really a simple press in. |
08-29-2017, 02:36 PM | #3 |
Drives: 2017 2SS Join Date: Apr 2016
I don't think you need to remove the internal trunk lid liner. I didn't do that when I replaced my 3rd brake light.
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
08-29-2017, 02:38 PM | #4 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
08-29-2017, 02:43 PM | #5 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
^ Like link in post above. You don't even need to open the trunk. Put painters tape on decklid around light. Maybe a couple of layers. Use a plastic trim tool and go around the light to loosen the 3M tape and pop the light out. It will then pull out and you can disconnect the plug. Use 3M adhesive remover to remove the stuck on 3M tape. You can use stuff like goo b gone but it will take longer. Clean off residue with isopropyl alcohol. Install the new light holding it as level as possible. On most cars including mine, the 3M tape on the new light is too thick and tries to push out in a couple of places at the top. Attaching top first might alleviate this.
08-29-2017, 02:48 PM | #6 |
I didn't have to remove my inside trunk liner. Using the trim tool to go around it to get the 2 way tape, basically pulled it out at the same time on mine.
08-29-2017, 02:57 PM | #7 | |
Your likely right... Lethal's video sent me down that path.... In hindsight, the pull and pry is likely sufficiant. It believe it did allow me to push a little from behind (if there is any value in it). |
08-29-2017, 03:36 PM | #8 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
I was ready to take out the liner, but I decided to give it a little pry first and mine lifted up pretty easy. then once i was able to get the pry tool under it, it popped out. just make sure you buy a thing of goo off, because the adhesive is on there pretty good.
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
09-16-2017, 09:53 AM | #9 |
GAHDOOSH
Drives: 2016 Camaro 1SS Join Date: Apr 2013
Anyone have a photo of this installed on a grey one with black tail lights to match?
GAHDOOSH
2016 1SS 6.2L LT1 Manual 6-Speed, Front Emblem Blackout, Rear Bowtie Delete, Side emblem delete, Phastek Side Marker Tint, GM Black Taillights, $23.57 of Premium Gas this morning |
09-16-2017, 10:15 AM | #10 |
Drives: 18 Colorado ZR2, 17 1LE(sold) Join Date: Aug 2013
09-16-2017, 10:46 AM | #11 |
SoCal Mayhem
Drives: 2017 2LT Hyper Blue Metallic Camaro Join Date: May 2009
I didn't read the other write ups, but a tip for removing the double sided tape and the light easier: get a pipette dropper ( a quick Google search yielded the following link http://m.pipingrock.com/aromatherapy...iABEgIYjvD_BwE ) and use it to put Goo Gone or whatever product you use into the tape around the border of the light. It'll soften it up and make it easier to pull off. I just did it this way about a week ago.
09-16-2017, 10:54 AM | #12 |
2017 SS
I used an old library card or you can use anu thin flexible card i guess. I inserted it into the seal area of the light and slid it aroind 2 times. Light came right out. This took about 3 min, cleaned the area up and put new light in.
05-25-2018, 04:01 PM | #13 | |
Drives: '17 2SS Vert H50, A8, F55, NPP Join Date: Jan 2018
Thanks for the tip. |
