Old 10-28-2020, 07:39 PM   #1
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
Hendricks Bushings recommendation
Anyone used Hendricks rear cradle solid bushings or Hendricks offset differential bushings?
Phastek has a great sale and I am looking for reviews.
Alternatively, I am looking at aFE rear cradle bushings. Comparisons?
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
Old 10-28-2020, 07:57 PM   #2
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
I have both Hendrix bushing sets. Their offset bushings eliminated my axle busting; the cradle bushings eliminated that floaty, “tail-wagging-the-dog” feeing as well. I would recommend them to anyone.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 10-28-2020, 08:06 PM   #3
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
How is the noise factor?
Old 10-28-2020, 08:49 PM   #4
demonspeed
demonspeed's Avatar
Drives: Camaros
Hmm... how do I put this... you can either solve a problem or not hear the gears - choose the option you find more important.
I don’t think it’s bad at all, but that’s subjective. I also have a BTR4 with long tubes so my exhaust essentially drowns the gear whine out.
10/13/22: 1100
Old 10-28-2020, 09:05 PM   #5
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
I have no frame of reference for the noise of poly or dermin bushing. I have been reading about it as an issue. I have stock exhaust that I am planning on replacing the axle back due to the drone, not quieter just tuned. Next summer I am putting in a stage 2 or stage 3 cam. I also have a JL Audio system if the noise is bad.
I also just have no idea what kind of noise is coming from the bushings.
Old 10-28-2020, 09:22 PM   #6
demonspeed
demonspeed's Avatar
Drives: Camaros
It is literally just gear whine - like if someone didn’t set up the rear correctly during a gear swap. For me it only happens when decelerating/coasting. Otherwise, it’s like stock.
10/13/22: 1100
Old 10-28-2020, 10:10 PM   #7
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
And the upside for the differential bushings is an improved angle for the differential on hard acceleration, so increased traction on launch. Anything else?
Old 10-29-2020, 09:15 AM   #8
demonspeed
demonspeed's Avatar
Drives: Camaros
It also is significantly less stress on the CV shafts as it helps to take the extreme angle off of them, especially if lowered. As soon as I got my car I busted two passenger side axles within a month - and I wasn’t even really pounding on it when they went. Ever since the bushings went in I’ve thoroughly abused the car on the street and road course and they’ve not had any issue whatsoever.
I actually talked to Thomas Hendrix himself before I ordered the parts as I was ready to spend the big money on better axles which he sells. He convinced me to just try the bushings first and I’m glad I took his advice.
10/13/22: 1100
Old 10-30-2020, 08:24 AM   #9
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
Curious - what is Phasteks sale? I’m looking at the Hendrix ones as well
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
TwentyTen2SSRS is offline   Reply With Quote
Old 10-30-2020, 09:40 AM   #10
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
$100 off, so they are $399 for rear cradle and the rear differential are on sale for $149. You can get both for less than the AFe rear cradle by itself.
Old 11-03-2020, 08:27 PM   #11
TwentyTen2SSRS
Drives: 2010 2SS/RS
Damn now that is a deal.
Anyone have ballpark on labor in hours at a shop? As much as I’d love to remove the rear end myself, I don’t have the proper tools to do the bushings.
I’d guess 4-5?
Old 11-03-2020, 10:22 PM   #12
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
I’d guess 4-5?
Watch a few videos sawzall and a MAP torch and your in. The diff bushings can be removed and installed with a $60 tool at summit. You got this!
Old 11-03-2020, 10:48 PM   #13
demonspeed
demonspeed's Avatar
Drives: Camaros
Differential bushings... I just used a reciprocating saw, chisel and hammer to get them out. Getting them in I had the bushings in the freezer over night and pulled them one at a time and hammered in with a rubber mallet after spraying the holes with dry lube first.
10/13/22: 1100
