Emblempros
Old 08-29-2010, 12:25 PM   #1
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
A6 transmission tune with hp tuners
what are you guys doing to the trans tune? does hp have a tune for it?
94guy is offline   Reply With Quote
Old 08-29-2010, 01:31 PM   #2
Camaro54
Camaro54's Avatar
Drives: Camaro SS2/RS orange/black stripes
I had my A6 tuned when the car was DYNO TUNED. You'll get you best tune overall this way. Leave D mode alone and have the M mode tuned more aggresive. I had 2nd and 3rd gears tuned. They now shift much harder.
Camaro54 is offline   Reply With Quote
Old 08-29-2010, 05:21 PM   #3
DSteck
Drives: 2006 Corvette Z06
HP Tuners does not supply calibrations... only the means to edit them.
DSteck is offline   Reply With Quote
Old 08-30-2010, 06:21 PM   #4
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
I got the most fun-to-drive out of raising the part throttle shift points for 'S' mode. This results in shifts around town in the 2500 to 3500 RPM range.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 09-07-2010, 10:06 AM   #5
RickyTheStorm
Drives: '10 Camaro 2SS,04 Colorado,06 ZX6R
I just tuned for higher MPH and higher RPM for WOT - my tuning shop is hard-core protect your transmission and didn't touch the shift points or TM on the tune even though I asked him to. Then of course when I told him I can just throw a racing tune on during racing and a standard tune on during normal driving he was all over the idea, figures
Anyway - golden rule of thumb here, do NOT remove TM completely if you are quarter-mile racing! I did just to make a couple laps to see what difference it made and, well besides spinning wheels in 2nd and 3rd gear shifts, the transmission would slip a little bit and I would run slower - so as a result, I have my TM tuned per gear: 1->2 70% (higher percent the more TM), 2->3 50%, 3->4 30%, 4->5 100% (5/6 are OD gears, don't want to blow them out), 5->6 100%
Thats how I ran for my 11.981 run and that's how I have run ever since. The only thing I modify now are shift points to try and get them right. And the shift points in the automatic are a PITA to tune because both a MPH must be set and an RPM must be set and both must be met to shift. Sometimes I hit rev limiter, sometimes I don't, I need to get it back to my tune shop and dyno tune the shift points so I can hit the end of the power band as well.
Vararam CAI, ARH Headers, Flowmaster Exhaust, Nitto NT555Rs, Custom CAM and Tune - 11.981 @ 116.27
IOM - 2SS/RS - Auto - IAP - Sunroof - Ordered 10/13 (#7 at dealer)
3000(accepted to production ): 4/19/09
3300 (scheduled for prod ): 5/11/09
3400 (broadcast ): 5/16/09
3800 (produced ): 5/22/09
4150 (invoiced ): 6/01/09
4200 (shipped ): 6/01/09
5000 (at dealer ): 6/12/09
6000 (delivery to me ): 6/12/09
RickyTheStorm is offline   Reply With Quote
Old 09-07-2010, 12:13 PM   #6
DSteck
Sounds like you need to cut your shift times down. I agree about completely removing TM, though.
If you're hitting the limiter sometimes, then a) I'd invest in a tranny cooler and b) your shift points are too high/late anyway.
Old 09-07-2010, 01:13 PM   #7
RickyTheStorm
Tranny cooler is already installed :-) I need my shifts hitting 6600 - that is where my power-band starts to level out.
I just have a hard time tuning this transmission because of needed to have the speed and the RPM right - of course I had just found the fuel cut off at 6400 - that may have been the problem with trying to get it to run the same every time
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
INTENSE Camaro ECM Tune w/ HP Tuners Package Rob@Intense V8 Bolt-Ons & Tunes 2 09-14-2009 02:48 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
