01-21-2016, 03:19 PM | #1 |
Drives: Turbo 4, SC V8 and Twin Turbo V8 Join Date: Jan 2014
FlowForm FF15 Wheels for 6th Gen Camaro INSTALLED! - Check Photos inside!
We know you have been waiting, but yes, we have fitment information and photos for you here on the FlowForm FF15 Wheels for your 6th Gen Camaro!! Below we have a selection of some photos during the test fit, then final installation shots so you can see how they sit on this chassis 19x10 ET25 front fitment 19x10 ET25 front fitment 19x10 ET25 front fitment 20x10 ET33 front fitment (requires 5mm spacer up front) 20x11 ET45 rear fitment 20x11 ET45 rear fitment Installed - 20x9 ET25 front 20x10 ET33 rear Available Fitments: Front: 19x10 ET25 - 23.8lbs Each - (Requires 3mm spacer up front to clear strut) Rear: 19x10 ET25 - 23.8lbs Each Front: 20x9 ET25 - 23.2lbs Each Rear: 20x10 ET33 - 24.4lbs Each Front: 20x9 ET25 - 23.2lbs Each Rear: 20x11 ET45 - 25.2lbs Each Front: 20x10 ET33 - 24.4lbs each (Requires 5mm spacer up front to clear strut) Rear: 20x11 ET45 - 25.2lbs Each Thank you for taking a look, give us a shout if you have any questions! Last edited by FlowForm_Wheels; 01-21-2016 at 05:55 PM. |
01-22-2016, 09:37 AM | #2 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
Looks good. What size tires did you go with? I would love to see that car with the Tarmac finish wheels.
01-22-2016, 09:56 AM | #3 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Not bad at all, needs lowering springs though...
01-22-2016, 10:15 AM | #4 | |
Oh yes, that would be a serious plus! |
01-22-2016, 10:19 AM | #5 |
#becauseracecar
OK Thanks! Glad to see a wheel company use the correct 30% aspect ratio tires with the 305mm rears.
01-22-2016, 10:40 AM | #6 |
those look good!
01-22-2016, 12:08 PM | #7 |
Drives: 2016 Black 1SS Camaro Join Date: Jul 2012
The wheels look great.
Would love to see concave back wheels just like the back wheels in the picture below. Are these available? I ask because I don't see the same angle/curvature in the wheels in the Camaro above.
2016 Camaro 1SS M6 with MRC and NPP.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” Albert Einstein Last edited by MIAMI2SSRS; 01-22-2016 at 12:22 PM. |
01-22-2016, 12:42 PM | #8 |
Gibson distorted that image since it's just a rendering, so that's just a dramatization. The most conical/concave face that we have is going to be used for the 6thGen Camaro, so you know you'll get the best look out there and achieve exactly what you're looking for.
01-22-2016, 02:05 PM | #9 | |
I am looking forward to see pictures of it mounted on the a 6th Gen Camaro.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” Albert Einstein |
01-25-2016, 08:06 PM | #10 |
Drives: 2016 V6 RS Camaro 6MT Join Date: Aug 2015
I absolutely love these ff15 wheels and I could definitely see myself picking up a set of these in tarmac.
I'd like to use the stock tires and see little reason to go to a staggered setup for a V6. Guess I should make a post about potential benefits of a staggered setup and the need to buy a new set of tires. My question. Front: 20x9 ET25 - 23.2lbs Each Rear: 20x10 ET33 - 24.4lbs Each From your post it looks like these fit. If I want to go square setup it'd be 20x9. Will 20x9 fit the 245 width stock tires? What would the rear offset be? 20x9 et33? Will the stock Chevy center caps work on your wheels? Or would I have to run the HRE center caps? Edit #2.... Just realized stock Chevy caps won't match your colors. Edit: Sent an inquiry via your website.
Summit White 2LT RS V6 ZN2 NPP m6 khalihari interior. Order placed 9/26/15 - Picked up 12/17/15!
02-01-2016, 02:38 PM | #11 | |
02-10-2016, 03:57 PM | #12 |
Thank you for all the messages! Looking forward to seeing some more pictures of FF15's installed
02-11-2016, 02:17 PM | #13 |
Drives: 2019 ZL1 1LE Join Date: Sep 2010
(this is effectively 20x10+28mm) >Front: 19x10 ET25 - 23.8lbs Each - (Requires 3mm spacer up front to clear strut) (this is effectively 19x10+22mm) The 20" wheel can get 6mm closer to the strut? |
02-11-2016, 02:19 PM | #14 | |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Im thinking exact same..... |
Thread Tools | |
