10-15-2014, 06:17 AM | #1 |
Drives: 2017 Jaguar F Type R Tuned 498awhp Join Date: Apr 2013
Upgrading the Radiator
Hello fellow members,
I was just wondering if it is worth upgrading the radiator on my 2013 SS at the same time of the cam install?
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
2017 Jaguar F Type R ''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller |
10-15-2014, 07:58 AM | #2 |
Drives: cars Join Date: May 2011
If you track it yes, otherwise not really.
10-15-2014, 11:57 AM | #3 |
Drives: ‘13 1LE Join Date: Jul 2013
Wouldn't which climate you race in play a role as well?
Same old dilemma on other car forums as well. Case in point, none of the BMW crowd here ever upgraded their radiators when road racing in MT. Tremblent, but a few hard core BMW club member and racers in North Carolina would. Race in stock form, 60% distilled water, 40% OEM coolant, add 1 bottle WatterWetter, then record your temps, and take it from there. In light of where Camaro500 lives, I highly doubt he will have to upgrade, unless his L99, AC equipped car runs a tad hotter than a LS3??(I don't know I'm asking). |
10-15-2014, 12:53 PM | #4 |
I'd say if you're tracking the car it would be beneficial regardless. If you live in a really cool area, then you may be fine, but the factory radiator is quite small and most aftermarket radiators are about double the size.
Best regards, Tyler 888-308-6007 |
10-15-2014, 02:25 PM | #5 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Here in Phoenix it is hot as hell in the summer and just hot the rest of the year and on the street the factory rad works . How ever if you are going to run it on a track ,in any climate it would be a benefit to upgrade the rad . And a Chevy is not a BMW. My 1LE runs 220 to 230 oil temp in the summer ,so I would not track it with the stock rad .
OLD GUY FLYING FAST AND LOW
10-15-2014, 05:17 PM | #6 |
10-15-2014, 09:00 PM | #7 |
Ok then, fair enough.
I think from a scientific perspective (since we are dealing with temperatures here after all), I must ask this question, to help out the OP here ultimately come to a conclusion on how to proceed with said possible mod. What would be the target coolant temperature to be looking for, the threshold if you will, where one must then conclude that's it's time to upgrade radiators? Is it 97C? 100C?? 120?? Surely, the OP can't be expected to just blindly upgrade, without jotting down some data collected from an actual track day event first? |
10-15-2014, 09:58 PM | #8 |
Drives: '14 1le Join Date: Jan 2014
Why not just install a 160* t-stat. Or program the fans to come on sooner.
10-16-2014, 04:31 PM | #9 |
I use 160 state and ran flat out for miles no problem wit temps. 178 water 244 oil.
10-16-2014, 06:06 PM | #10 |
When is enough ever...
Drives: 2006 Silverado 2500HD CC/SB LBZ Join Date: Apr 2011
Location: Residence: Chula Vista, CA Home: Billings, MT
Outside influences definitely play a part in your engine temps and subsequent health. I've run Spring Mountain (20 minute sessions) in 50 degree (F) and in 100 degree temps. My car was running intake, cam, LT's, tune, and 160 thermostat. All with a stock radiator. The coolant temps at the end of those sessions were 220's on the cool days and high 240's on the hot days. Engine oil temps were 250's and 290's respectively. Bottom line, anything you can do to cool the engine is going to build power and prolong life. A larger radiator is a great addition to the cooling puzzle but one should not over look the cooling effects of oil as well. Use of an oil cooler will help immensely. Furthermore, oil cooling of the internal components has proven to be MORE effective than traditional water-based "coolant". There is a reason you see oil coolers on high performance engines and there is a reason you see piston oil squirters on turbo charged diesels and now on supercharged engines like the LSA and LS9.
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing |
10-18-2014, 06:31 PM | #11 |
The oil cooler upgrade is a most excellent point!!
When I stroked and turbo charged my previous BMW ride, I kept the radiator stock(as in original one installed from assembly line, that lasted me 400000km!) but upgrading the oil cooler to a much more efficient unit was an absolute must to include in my "budget minded" build. The "4 season" coolant thermostat also was ditched in favour for for one used from the parts bin in the Arab countries, since it was, a summer only car . Now, I'm new in the LS3/L99 arena, so I'll just sit back and listen here to other peoples testimony, as I too, like the OP, are learning about the base line capabilities of these engines in stock guise. |
10-25-2014, 04:11 PM | #12 |
Well it looks like even track bred Z28 suffers from exceedingly high oil temperatures according to today's forum home page Z28 vs world test. Here is a quote from that article I copy and pasted below.
This is a hot romance in the making—but then it gets too hot. Although ambient temperature is barely in the 80s, three hard laps are enough to send the Camaro's oil temperature around the dial and beyond the 300-degree mark. "Unacceptable in any high-performance street car," Cammisa gripes, "especially one with this much track capability." The Aston and Nissan have been getting hot, but not like this. It's a reminder that the Z/28 is fundamentally a development beyond what was originally intended for the Camaro platform. |
11-12-2014, 10:17 PM | #13 |
11-13-2014, 03:28 AM | #14 | |
Because you didn't know of the issue doesn't mean I'm telling people to blindly upgrade. And the OP never even came back to the thread to discuss his intended use for the car so I don't see a need to provide clarifications to questions that he never asked. He can look for a number of threads on the topic, he's not the first person to run at a track so other peoples, including mine, real world experience is what I was basing it on. |
