Old 03-03-2015, 04:18 PM   #1
psm3234
Drives: 2016 2SS hyper blue metallic
getting tune for your SS
ok, I get it. mod your vehicle and then get a tune to get the most out of the mods. if you DO NOT do any mods, does a tune help the performance of you car in any way????
psm3234 is offline   Reply With Quote
Old 03-03-2015, 04:21 PM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Yes it does, but you would be lucky to get more than 15 or 20 whp from it without mods. Then when you do your mods you'll need to re-tune it.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-03-2015, 04:32 PM   #3
psm3234
I am not going to mods. do you suggest a tune or should I just buy crown royal with that money????
Old 03-03-2015, 04:35 PM   #4
mbowen89
Drives: 2015 CRT 2SS/RS 1LE
Unless you want to void your drivetrain warranty, don't tune it. I think most would agree!
mbowen89 is offline   Reply With Quote
Old 03-03-2015, 04:36 PM   #5
1KillerSS
1KillerSS's Avatar
Honestly, I would do it if your not going to do any mods, but thats just me. Tuning was the first thing I did with my car. However I had the tools and resources to work on the car myself at the time, so I could play with it and learn.
Curious as to why you dont want to mod your SS, is there any specific reason for that?
Keep in mind that that HP estimate is on the high side.
Build thread
Old 03-03-2015, 04:38 PM   #6
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
From what I gather if you have an auto then the change is pretty dramatic. If you have a manual there will be less of a noticeable difference.
9/26/09 Took delivery!
Old 03-03-2015, 04:39 PM   #7
1KillerSS
1KillerSS's Avatar
Thats not necessarily true, many people have had plenty of warranty work done to their cars and have been tuned. Search the forums a little.
You will most certainly void your warranty, yet if the failure was not related or caused by your aftermarket modification then your good....granted your with a decent car dealership.
Build thread
Old 03-03-2015, 04:41 PM   #8
The_Blur
Moderator
The_Blur's Avatar
Buy some Crown Royal. The tune is going to need to be updated if you change your mind later, meaning you'll have to spend extra for marginal benefit.
warn 145:159 ban
Old 03-03-2015, 04:47 PM   #9
mbowen89
I know to a degree what you said, and I know this is discussed every day over and over but my understanding is if his engine blew for some random reason even without mods, when GM sees the tune he doesn't get a new engine. I know that the tune has nothing to do with bad radio or exhaust, but I'm more worried about engine going out as high dollar repair. That's why I thinking it would be the biggest risk to tune for no mods, for relatively small gain. Maybe I'm completely wrong here, but I still think the issue of warranty work is something be should definitely keep in mind if tuning even with no mods.
Old 03-03-2015, 04:49 PM   #10
The_Blur
Moderator
The_Blur's Avatar
This is hotly debated, but the facts are that a computer controls engine operation. If that tune causes a malfunction or reduces the durability of that engine, failures in that engine that result are not the manufacturer's problem.
warn 145:159 ban
Old 03-03-2015, 04:52 PM   #11
1KillerSS
1KillerSS's Avatar
The risk of tuning for mods, VS no mods is minimal, basic bolt-ons are really no big deal, your tune will be changing basically the same parameters that it would change if you had the mods, just not to the same degree.
The dealer isnt going to care if you modded your car with a tune only compared to mods and a tune. To them its all the same....basically.
Build thread
Old 03-03-2015, 05:04 PM   #12
mbowen89
I know, but how do you know you didn't get a dud engine that is gonna blow at 5k miles, and you got a tune (for no mods even!), and GM says sorry!?
I mean, I guess I'm playing worst case scenario and the dealer won't even realize you tuned it, I'm just going worst case that engine needs replaced, etc, the big stuff.
Old 03-03-2015, 05:05 PM   #13
stirrup shifter
Drives: camaro
Get a quality tune. You're far away but reach out to Tampa Tuning - Phil can help. The tune he put on my SS just woke it up. The street tune on the motor and A6 tranny makes it way more fun to drive and we killed the AFM......sounded great before I did any mods. These cars are way more fun and powerful than the factory sends out.....
stirrup shifter is offline   Reply With Quote
Old 03-03-2015, 05:28 PM   #14
1KillerSS
1KillerSS's Avatar
If your thinking is that as long as your mods, or lack of, are minimal, GM wont notice or mind, then you're wrong. GM will notice you tuned it. As soon as they plug in their scanner they can tell that its been modified, it won't matter to what degree its been changed, its still altered.
Build thread
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
