02-07-2015, 04:29 PM | #1 |
Drives: Summit White 2014 1LT Join Date: Feb 2012
Magnaflow Round Mufflers
I know some Camaro owners have custom Magnaflow exhaust systems.
Does anyone have a system with the Magnaflow round mufflers? If so, what muffler diameter (4 in, 5 in, 6 in, or 7 in) and length? What how does it sound? |
02-08-2015, 05:02 AM | #2 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
I had some magnaflow round I think they were 4" round by 14" long. They didn't work at all, they created a lot of drone. I ended up taking them off and running straight pipe with the magnaflow resonated xpipe, which has less drone. It must have been the angle they were mounted or something but they definitely created drone.
3.6L Twin Turbo V6 Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension 10.75 @ 131mph |
02-08-2015, 07:42 PM | #3 | |
Thanks. I've got a couple different directions I've been thinking of going. |
02-09-2015, 02:06 AM | #4 |
Drives: camaro Join Date: Feb 2015
well, It must have been the angle they were mounted or something but they definitely created drone.thanks
02-09-2015, 11:08 AM | #5 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Don't use them. Like the guy above me said, they drone like hell. I'm getting mine taken off.
02-09-2015, 08:46 PM | #6 |
Thanks all!
All the Magnaflow oval mufflers sound pretty smooth and have a nice rumble to them. I'm thinking the direction I may go is to get a set of Magnaflow oval mufflers and have those put on the stock pipes...hoping I can salvage the stock tips. Just need to find a decent place to put them on. Also pondering having the stock resonators removed...not sure though. One step at a time! |
02-09-2015, 08:54 PM | #7 |
Drives: 2010 2SS/RS Join Date: Jan 2013
I have round magnaflows 5inch round body 3" inlet outlet 14" long
Sounds mean!! |
