11-06-2020, 01:48 PM | #1 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
Nitrous maybe?
So i have decided to not do business with Will or go forced since he is like a black hole nowadays and not a fan of Procharger after some reading.
My current thoughts are come spring install a 50 shot of nitrous (or smaller because i'm a noob) since dollar for dollar it appears to be the best bang for the buck along with a gear change. NOT blowing up would also be nice. Who makes a simple and SAFE kit for a beginner like myself to install?
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
11-06-2020, 05:36 PM | #2 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
I'm not a big fan of nitrous unless you're building a balls out drag car and even then it's not for me. My old school brain kicks in and says this is more for a stout V8 engine/set-up. Read: 454, Turbo 400 and 3:73 gear 12-bolt. Seems to me it's an easy way to start breaking expensive LFX parts. But if you're doing improvements what have you already done? Are you manual or auto? What are your intentions/goals and of course, what's your budget?
11-06-2020, 07:22 PM | #3 |
Drives: 02 Camaro B4C Join Date: Nov 2016
There is no such thing ass a "safe" nitrous kit. Sure lots of people have been using it and never had a problem, but it just take one small failure or tune error and your looking for a new engine.
There are lots of good shops around depending on the type of power your are interested in. You don't mention if you have done anything to the car yet. If you only want a little HP increase then headers and exhaust can give you that. Its also a good starting point for more improvements down the road. If you want a bit more then heads, cam, & intake can give you some real nice power. If you are looking for more than that the either a turbo set up or a blower is the way to go. If you don't like Procharger then look at Whipple or Magnacharger. Good luck.
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
11-07-2020, 12:51 AM | #4 | |
Give speed a chance
11-11-2020, 09:12 AM | #5 |
Drives: 2014 Camaro Join Date: Feb 2020
A wet 50 shot should be pretty safe just only spray at wide open of course. 50 is not going to feel like much so more than likely you'll want to go with a higher shot. That's when things can start to go wrong. Don't cheap on this, get something that has a progressive controller.
Bad thing with nitrous is its best only at full throttle and you need to constantly fill the tank. With a supercharger you have power every where, all the time. Prochargers tend to run hot but as long as you adequately cool the charge and have a good tune you'll be fine. |
