Old 04-30-2018, 07:17 AM   #1
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
FS: 1LE Oil Separator - SOLD
SOLD
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 04-30-2018, 09:26 AM   #2
Vandal0-0
Vandal0-0's Avatar
Drives: 2010 CAMARO 2SS/RS
Ship to Canada
Vandal0-0 is offline   Reply With Quote
Old 04-30-2018, 11:54 AM   #3
J Rod
J Rod's Avatar
Originally Posted by Vandal0-0 View Post
Ship to Canada
Probably not, last time I got a quote it was fairly expensive. I can take a look though, what is your zip?
592 HP/590 TQ
Old 04-30-2018, 12:50 PM   #4
Vandal0-0
Vandal0-0's Avatar
Really I order everything from the states and shipping isn’t bad T4B0B3
Old 04-30-2018, 01:41 PM   #5
J Rod
J Rod's Avatar
Must be cheaper for businesses I guess. To ship a small 1lb box to your zip, USPS quoted $47 and UPS $31. Not sure why it's so outrageous. My zip is 46818 if you'd like to check for yourself.
Old 05-08-2018, 09:39 AM   #6
J Rod
J Rod's Avatar
Bump
592 HP/590 TQ
Old 05-09-2018, 10:12 AM   #7
str8wick3d
Drives: 2011 Camaro SS
can this be ran without the engine cover on? also in the 1le kit it looks like it came with a pcv pipe not hose, did u modify?
str8wick3d is offline   Reply With Quote
Old 05-10-2018, 04:13 PM   #8
J Rod
J Rod's Avatar
Yes you can run it without the engine cover and yes they do come with a hard plastic hose from the factory. The connector on it won’t work with aftermarket intakes though, hence the rubber hose.
592 HP/590 TQ
Old 05-16-2018, 01:37 PM   #9
J Rod
J Rod's Avatar
bump
Old 05-31-2018, 06:53 AM   #10
J Rod
J Rod's Avatar
back up
Old 06-02-2018, 08:35 PM   #11
truepatriotmjm
truepatriotmjm's Avatar
Drives: 2015 2SS/RS with Twin Turbskies
PM sent
truepatriotmjm is offline   Reply With Quote
Old 06-17-2018, 09:33 AM   #12
J Rod
J Rod's Avatar
Bump
592 HP/590 TQ
