#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Road Course/Track and Autocross
AWE Tuning
Old 11-16-2022, 12:13 AM   #1
Robster
Robster's Avatar
Drives: 2017 Camaro ZL1, 6M
To track or not to track - Heat Cracked Rotors
I plan on going back to the track soon (ACS)... Do you think I have one more session left in these rotors or should I replace them?
I can just barely feel with my fingernail the bigger crack seen on the bottom image.
Robster is offline   Reply With Quote
Old 11-16-2022, 08:25 AM   #2
Melon
Melon's Avatar
Drives: '23 1LE, '18 Canyon, '87 325i
They usually get a little larger before it's a real problem, but if you can, I'd replace them.
https://www.essexparts.com/news-blog...-my-iron-discs
Melon is offline   Reply With Quote
Old 11-16-2022, 08:55 AM   #3
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
Those rotors are perfectly fine, you have plenty of life left in them.
Christian1LE is offline   Reply With Quote
Old 11-16-2022, 10:32 AM   #4
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
plenty of life send em !
kropscamaro16 is offline   Reply With Quote
Old 11-16-2022, 11:10 AM   #5
Osbornsm
Drives: 2018 SS 1LE
Agree, they're hardly worn / cracked yet.
You are all good sir.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 11-16-2022, 12:42 PM   #6
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
Essex parts has a great article on determining when your iron discs need to be replaced. Some pictures in this article are way more heat checked then your discs.
Nick S is offline   Reply With Quote
Old 11-16-2022, 01:16 PM   #7
ATl_1LE
Drives: SS 1LE
Agree with others, i just started looking at mine since last event, still over min thickness but cracks getting noticeably worse
ATl_1LE is offline   Reply With Quote
Old 11-16-2022, 10:38 PM   #8
Robster
Robster's Avatar
Thanks for the feedback, everyone! Good to know that I can run them some more.
Old 11-16-2022, 11:55 PM   #9
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Drives: 2020 2SS - A10, NPP, MRC, CAI
https://www.camaro6.com/forums/attac...1&d=1668625913
Wow, I'm not knowledgeable of tracking a car, but if I was going to and I looked at my rotors and saw that many cracks I'd be installing new rotors before I ever saw the track!
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
2SS Capt is offline   Reply With Quote
Old 11-17-2022, 05:53 AM   #10
cdrptrks
cdrptrks's Avatar
Drives: 2017 Blue Camaro 1SS 1LE with PDR
My front rotors that I installed about 1 year ago look like the one ATl_1LE posted and still have 2/3 of their usable thickness remaining (original vs. discard). I'm using stock pads which don't wear the rotors quickly. The picture shows heat checking and it is normal if you track the car. It is fine as long as there are no cracks all of the way to an inside or outside edge and as long as the rotors are above minimum thickness.
Robster, measure your rotor thickness to confirm but you're probably fine.
cdrptrks is offline   Reply With Quote
Old 11-17-2022, 06:04 AM   #11
cdrptrks
cdrptrks's Avatar
I accidentally ran my last set of front rotors below minimum thickness due to the outside lip touching the calipers I was measuring with before the tips touched the rotor which I didn't realize. I probably would have caught the few cracks that I found earlier turning the rotors by hand and inspecting the inside using a flashlight with the front wheels removed but thankfully I noticed them from the front before they catastrophically failed. There were more cracks not yet visible from the front that I found after removing the old rotors. I had a slight vibration under braking during the session before I found them.
Old 11-17-2022, 06:08 AM   #12
cdrptrks
cdrptrks's Avatar
I drilled some material out of a cheap set of Harbor Freight plastic calipers to clear the lip for future measurements or there are more expensive measurement devices that already have more than enough clearance.
Old 11-17-2022, 03:53 PM   #13
ATl_1LE
Drives: SS 1LE
Yup, this is exactly what i started looking for as i've grown accustomed to heat cracks on the cars i've been tracking as normal, Oem and aftermarket. Mine are getting noticeably closer over the past few events and still above min width but not by a ton so most likely going to replace over the winter.
Hadn't been looking that far inside for the cracks in your pics though, something to look at.
Old 11-17-2022, 04:40 PM   #14
cdrptrks
cdrptrks's Avatar
For sure, I was focusing on checking the outside edge and not thinking much about the inside edge but maybe the wear lip prevented a crack from going all of the way to the outside edge.
