Old 11-07-2016, 06:06 PM   #1
SSjosh
SSjosh's Avatar
Drives: 2011 SS 6MT
Clutch Slave Interchangeability
I have searched low, I have searched high, can't seem to find what i'm looking for. 2010 SS bolt-on, stock clutch, 28k miles. I must have been through every throw out and slave thread in this place.
My slave isn't even bad but the throw out is. I'd buy just a bearing if I could? and throw in a speed bleeder and monster bushing.
On Gmpartsdirect, PN 19210297 (M10) is discontinued.
Is there any difference with PN 24266013 (MM6) or the ZL1 PN 24249220? I.E. will they fit?
Rockauto has a centric replacement for 2010-2011 but not anything 2013+ that I saw, but if there is a different design within gm (that lasts longer), I might choose an o.e. replacement.
Can any of you guys positively clear this up for me?
Thanks
SSjosh is offline   Reply With Quote
Old 11-07-2016, 06:21 PM   #2
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 NPP BRM
Check out this thread Correct Slave Cylinder for LS3 http://www.camaro5.com/forums/showthread.php?t=427258
camguynj is online now   Reply With Quote
Old 11-07-2016, 06:43 PM   #3
SSjosh
SSjosh's Avatar
Drives: 2011 SS 6MT
I know that 19210297 is the correct one. However, wondering if the others are interchangeable, better design, better bearing?
I'm half tempted to find just a bearing once I get the slave out unless someone else has done the leg work on the dimensions.
Old 11-07-2016, 08:26 PM   #4
camguynj
camguynj's Avatar
Monster has one and you can have them pre-install their Billet Release Bearing Support http://monsterclutches.com/gen-5-cam...slave-cylinder
Old 10-31-2020, 08:42 AM   #5
camguynj
camguynj's Avatar
NEW from Tilton...self adjusting throw out bearing with braided SS lines with adapters for Camaro Tremec6060. The braided SS bleed line eliminates the need for a separate remote bleed line
https://www.tickperformance.com/tilt...owout-bearing/
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
