Old 12-09-2019, 06:19 PM   #1
10camaross2ss
Drives: 2010 camaro ss 2ss
Smallest rims possible for 2010 ss
Hello. Anyone what's the smallest rims u put on your
5gen. I am putting in a lift in my garage and for winter storage I thought I could gain ceiling clearance by putting on smaller rims. 5 x 120's on... Problem will be clearance with the brembos I think
10camaross2ss is offline   Reply With Quote
Old 12-09-2019, 06:24 PM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Well, some 17s will fit with stock brakes. I think if you do a v6 brake swap you can put 15s on.. tho i don't wholly understand why you want smaller wheels
Greenhornet2 is offline   Reply With Quote
Old 12-09-2019, 06:26 PM   #3
'10CamaroDude
Drives: 2010 Camaro LS
Right there...
'10CamaroDude is offline   Reply With Quote
Old 12-09-2019, 06:42 PM   #4
10camaross2ss
Originally Posted by '10CamaroDude View Post
Right there...
😂 Thought also storing it on crap rims Incase I need the lift and have to pull car out in the winter
Old 12-10-2019, 08:51 AM   #5
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Right there...
How much room do you expect to gain? I mean the car isnt that high so eventually you would be too low for the lift.
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 12-10-2019, 09:23 AM   #6
Juiced1
Drives: 2012 2SS CAMARO 45th
How about some lowering springs. They give you a great stance, make it more fun in the turns and you won't have to swap your rims every time you want to park your car. Probably a lot cheaper then a second set of rims too
Juiced1 is offline   Reply With Quote
Old 12-10-2019, 09:26 AM   #7
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Totally thought this was going to be a drag racing purposes/traction/sidewall thread when I saw the title..
Greenhornet, Some grinding of the LCAs goes along with it. Ryan Stevens had to grind when he had the V6 brakes.
11.079 @ 122.99mph
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 12-10-2019, 10:11 AM   #8
Greenhornet2
When I think lift I am thinking 2 post that picks up on the frame. I suppose you could mean a drive on lift, I wasn't thinking about those. 17s with low pro tires might get you down to maybe a 25" tire? lowering springs are my vote tho.
Old 12-10-2019, 12:33 PM   #9
HDRDTD
AFAIK, If you have the Brembo brakes, in order to clear them you're going to need either a 20" wheel, or use spacers on a smaller wheel to clear the brakes.
Old 12-10-2019, 12:51 PM   #10
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
A lot of us run 17" drag packs with Brembos. The only mods I had to make were to cut the roller skates off the front pads and tie back the e-brake cable in the rear.
CAI Cold Air Intake; Comp Cams LSR Series; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; AEM Wideband; N2MB WOT Box;
Tuned by Throttle Works 467whp 419 wtq
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 12-10-2019, 12:54 PM   #11
mikeman
Banned
Drives: 2015 Camaro
I thought about this, but then I think about the scraping over speed bumps and steep driveways.
mikeman is offline   Reply With Quote
Old 12-11-2019, 04:07 PM   #12
10camaross2ss
Had a low rider ranger (5" drop) as a teen. Never again
lol
Old 12-11-2019, 04:11 PM   #13
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Even if you run a 17" wheel. That's 3" less. Say you run a 3" less tire to match.. that's still only 1.5" a side. All that work for 1.5" more clearance?
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
Old 12-11-2019, 09:20 PM   #14
Vegas Bound
Drives: 2013 Sparkly Red One
This ^^^^^^^^^
Vegas Bound is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
