Old 03-25-2020, 07:42 PM   #1
LS3_SPEED6
Drives: SS
Exclamation Spark Plugs for Procharger Low Boost: TR6 vs BR7EF
The time is come in my build to put in spark plugs. There seems to be a huge debate. From what I have seen, most seem to run either TR6 or BR7EF. My car has headers, P1SC-1, only setup for around 7-8lbs. Fuel includes 93 and e85, and in between due to flex fuel. Anyone with similar setups running either? What did you gap them to? The car is more of a summer daily with cruising and highway fun. I do see stop and go frequently. Thanks.
LS3_SPEED6 is offline   Reply With Quote
Old 03-26-2020, 02:13 AM   #2
eLeSthree
Drives: 2011 Camaro SS 6sp
TR6. The br7ef has a non projected tip. I found them to drive horribly. Plus you dont need a 7 heat range plug for 600-650whp.
Tr6 gapped at 35
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Tuning Triples and FF, FIC1300, Mcleod RXT 1200HD, 1030whp 925wtq.
eLeSthree is offline   Reply With Quote
Old 03-26-2020, 07:56 AM   #3
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
TR6IX on my YSi at 8lbs work fantastic and idle extremely well. Gen consensus, is TR6 up to approx 10lbs.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
