08-16-2020, 10:51 AM | #1 |
TPS Relearn issue,
2013 SS. Swapped wheels out with ILE take offs with sensors from factory. Not sure of what year they are, but would guess 2019 or 2020. Using EL 50448 relearn tool. Won't read tool. What is my next option?
08-16-2020, 11:06 AM | #2 |
2010-2015 gen 5 Camaro's used 315mhz tpm's. I believe 2016 to present 6 gen Camaro's use different MHz tpm's.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
08-16-2020, 11:14 AM | #3 |
08-16-2020, 11:17 AM | #4 |
I have 4 used but good gen 5 Camaro tpm's sensors and will have 4 more shortly if you run into a problem getting new ones.
08-16-2020, 12:36 PM | #5 |
It's TPMS, not "tpm's", there is no possessive form of it.
You're using it as if saying; "Hey, that is Tpm's, put it down." Or, "Tpm's gonna be mad at you" As in, TPM IS... TPMS, the ACRONYM. There is no apostrophe in it, EVER. |
08-16-2020, 01:58 PM | #6 |
Is that the best you got? You have anything technical to help the OP with his issue ?
