Old 03-15-2011, 03:11 PM   #1
SS>GT
SS>GT's Avatar
Drives: 2010 Camaro SS
would removing two cats help?
i noticed that even though the camaro has 4 cats, the sensor is after the first set. There doesnt seem to be a sensor after he second set.
Question is, is it worth it to remove the last two cats? would it affect HP, Engine lights, etc..?
Any help appreciated.
2010 camaro 2ss LS3
Corsa catback exhaust w/muffler delete, hennessey intake, Pfadt springs, Hurst Short throw Shifter, Murdered black.
GO TEAM LS3
SS>GT is offline   Reply With Quote
Old 03-15-2011, 03:14 PM   #2
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
You would probably get a better answer in the exhaust section.
Old 03-15-2011, 03:15 PM   #3
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Removing cats will always increase horsepower. Not sure if they will throw a code though...
DarkneSS is offline   Reply With Quote
Old 03-15-2011, 03:18 PM   #4
1bad65
Banned
Drives: 2007 Mustang GT
On my car if you remove the back 2 cats, you will get a Check Engine light. If you turn off those two O2 sensors with a tuner the Check Engine light will go off, but you will get 2 "Not Ready" errors when you hook it up to the computer to get the car checked for a vehicle inspection. Not all States/counties/cities require the car to be hooked up though, so I'd suggest you do some research before removing them.
1bad65 is offline   Reply With Quote
Old 03-15-2011, 03:19 PM   #5
upflying
upflying's Avatar
Drives: '86 Monte Carlo SS
Since you live in LA, you can bet the smog check visual inspection will catch the missing cats.
upflying is offline   Reply With Quote
Old 03-15-2011, 03:20 PM   #6
mikeSS
mikeSS's Avatar
Drives: 2015 c7
high flow cats, come with one cat. and tons of people are not throwing codes.
Old 03-15-2011, 03:25 PM   #7
Russell James
Russell James's Avatar
I think a high flow single cat is a better option. Bolt in. That way you are leaving your OE cat pipes intact. And if you ever need to put it back to 100% stock it will be easy. Cut between the two cats, and tough and expensive to return to stock.
Old 03-15-2011, 03:35 PM   #8
mrh923
mrh923's Avatar
Drives: 2011 Camaro 1SS/M6 Cyber Gray Met.
I just ordered the high flow cats from solo performance. They say that it won't throw a code and it increases the sound and performance. Somewhere around 25 for both HP and torque increase.
2011 1SS/LS3 M6--Vararam CAI-Corsa catback-Dynatech LTs-RX Catch Can-Vmax ported TB-Eibach Springs-Night Fury Camshaft- 486RWHP/458 TQ
mrh923 is offline   Reply With Quote
Old 03-15-2011, 03:52 PM   #9
bmorecam
So if a company like bbk is saying that their long tube will give you a gain of up to 30hp with high flow cat than does that mean that 30hp number will go up with no cats? I know with turbo cars getting rid of the cats will give you alot of extra horses from my past experience but I heard that you will not see too much of a difference with a n/a car with no cats. Maybe someone with more expertise can verify?
Old 03-15-2011, 04:04 PM   #10
SS>GT
SS>GT's Avatar
Is that 25hp because you have an intake and exhaust, or 25hp on stock?
2010 camaro 2ss LS3
GO TEAM LS3
Old 03-15-2011, 04:12 PM   #11
mrh923
mrh923's Avatar
That's stock I believe. But you should look at their website. They've got the dyno sheet on there. They are 575 but Maryland speed has the jba high flows for 392.
Old 03-15-2011, 04:25 PM   #12
Steve Dallas
Commits weekly crime
Steve Dallas's Avatar
Drives: 2017 Camaro 1LT
sad cat is sad!
2017 Camaro 1LT - Blue Barchetta IV
I fire up the willing engine, responding with a roar. Tires spitting gravel I commit my weekly crime.
Steve Dallas is offline   Reply With Quote
Old 03-15-2011, 04:29 PM   #13
1bad65
Banned
I should have been more specific. When you remove them, you throw a code. When you put hi-flow cats on, you don't throw a code.
Also, one cat? I have two on mine, I just assumed the V8 Camaros would need two as well. My hi-flows are small, about the size of a fist.
Old 03-15-2011, 04:30 PM   #14
ViperTomcat
Banned
Drives: 2011 Avenger Heat
ViperTomcat is offline   Reply With Quote
Removing cats? Kwik Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 02-24-2011 03:32 PM
WILL REMOVING CATS INCREASE HP & TQ ? iom Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 08-11-2010 08:51 PM
Modern Muscle Exhaust and Intake Special modern-muscle V8 Bolt-Ons & Tunes 1 01-20-2010 06:46 PM
Removing the Cats? ctk1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 55 12-27-2008 10:59 PM
