02-10-2018, 09:57 PM | #1 |
618 RWHP
header questions ?
I am running stock manifolds with cat delete pips and stock exhaust.
With my mods I am running 14.1 pound of boost at peak . 1, if I put on a pair of KOOKs headers and off road pips . Will that lower my boost ? if so how much ? 2. if I have the headers coated with a 2000+ degree coating will that keep the engine bay cooler then the stock manifolds ? 3. Will the headers make the exhaust sound loader in the cabin ? then the manifold ? 4 When running header and off road pips and stock exhaust is there a lot of droning sound ? |
02-10-2018, 10:03 PM | #2 |
Drives: '11 2SS/RS LS3 M6 (Sold) Join Date: Dec 2015
1. Yes it should lower boost, I don't know exactly how much. Around 2 lbs I would say.
2. Don't know, but I would imagine so. 3. Yes, very much so. Headers make these cars extremely loud. 4. Yes there will be a good bit of drone once it hits the certain resonance RPM, thats why I went with Corsa, I don't have cats and I have absolutely no drone.
2011 IOM 2SS/RS LS3 M6- Injen CAI, TSP 1 7/8 headers, PTB, Hurst short throw, Corsa catback exhaust, 20" TSW Nurburgrings, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. 3660lbs. Tuned by me (sold)
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2 headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20/18 Weld Belmonts, 3550lbs. |
02-10-2018, 10:17 PM | #3 | |
Drives: Fast Join Date: Mar 2015
2) Probably not. But maybe. 3) Yes, the exhaust will be louder but you already have the cats deleted, so there's not much sound to be gained from changing the manifold to a Header style. It will sound good paired with the stock NPP exhaust and you'll have the ability to run the valves open or closed on the mufflers depending on what volume you're after. 4) There's likely some drone but I do not think they drone much, if they did then there's no way it would be the most popular ZL1 exhaust setup (Which it is, probably by a power of 4 to anything else). I say do it and don't look back. You'll have to get her tuned though so if there's any other mods you want to bundle in like a Pulley or Intake/Throttle body etc. then do it at the same time. |
02-10-2018, 10:18 PM | #4 | |
618 RWHP
02-10-2018, 10:20 PM | #5 |
There's only one option for Corsa on the ZL1, the sport 3" system and it sounds awesome. However, Corsa's zero drone policy is based on stock headers/cats. If you have are running headers/no cats/high flow cats then it will drone a little bit, though probably less than stock. It will be WAYYYYYY louder than stock though I can tell you that. LSA + Headers + No cats + Corsa 3" is as loud as you're going to get an LS engine. You have no valves to close either. It's going to scream all the time unless you keep the RPM's under 3000. If you hammer on it, everyone for 2 miles+ is going to know.
02-10-2018, 10:25 PM | #6 | |
02-10-2018, 10:28 PM | #7 |
Yeah I rode in a Cammed ZL1 with Headers + no cats + Corsa and it sounded awesome and like typical Corsa it is an expertly tuned setup that is manageable if you keep the RPM's in "cruising" range. But yeah, WOT and she SCREAMS. Also had seat time in a ZR1 with the same setup (No cats, headers, corsa, cammed) and same thing, great cruising sound and idle, manageable levels. But WOT and the whole area code knows. When he left the party at my place, he jumped on it off a stop light about half a mile down the road from me and it was bordering on REALLY loud even from that far away (As in, sounded like the car could have been in my driveway).
02-10-2018, 10:57 PM | #8 |
618 RWHP
Thank you all for the info
02-11-2018, 12:25 PM | #9 |
Drives: 2012 ZL1 Join Date: Apr 2015
I have headers, no cats and npp stock cat back with the fuse pulled and I love it ! If I'm just cruising around and easy on the throttle it's not bad for drone .... but at W.O.T it's barbaric !!!!!!!!! I love it
2012 ZL1 preproduction car #13 ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet |
02-15-2018, 11:54 AM | #10 |
Drives: 2015 ZL1 Blue Velvet Metallic Join Date: Mar 2015
"Will there be drone" is a very subjective question. I loved mine with 2" ARH, catless and stock cat-back, no drone in my opinion. When I swapped the cat-back is when I was no longer happy. If I had to do over again, I'd do long tubes, catless or high flow cats and stock exhaust.
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
02-17-2018, 09:59 PM | #11 |
Just threw on 2" texas speed headers with off road connection pipes and it's a very big difference probably more than just doing a cat back and no headers.i do have to say that's it sounds amazing, it gives the car a sound it deserves.
2015 zl1 rotofab,pnpblower,2.35,e85,2"headers catless. 650(93)700(E85)
