05-13-2014, 03:25 AM | #1 |
Drives: 2015 1SS, 1LE, Recaro, NPP Join Date: Apr 2014
Performance/cosmetic mods
So, I have my 2015 1SS 1LE with Recaros and NPP on order but the wait is killing me. I need to start buying some parts to cope with the waiting. I'm already getting the CAI black powdercoated intake and skip shift eliminator, but was wondering what else I could add for performance without voiding the warranty. I was thinking of possibly adding the VMAX Spiral Ported Throttle Body, is it worth it? I live only 10 miles away from Whipple, so let's how long it last before I get one of those. Cosmetically I think I just want to do tint and black out the bowties, anything else you guys do to yours? Let me hear back from you, so I can get ideas for mine.
Thanks. |
05-13-2014, 03:50 AM | #2 |
Drives: 2014 Red Hot 2SS/RS/1LE NPP Recaros Join Date: Sep 2010
My recommendations for you, as I will be doing the same.
Clutch reservoir Replace your yaw sensor with one from an automatic Camaro (to get rid of the HSA nanny) ZL1 splash guards Clear Bra Sent from my iPad using Tapatalk |
05-13-2014, 04:30 AM | #3 |
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH Join Date: Jan 2014
Catch can for sure. I had a good experience with RX. Elites are very popular on this forum. I'd get the larger Elite2 if going that direction. Since you're interested in appearance, Rx is the only one to my knowleedge that includes a custom color paint match to GM colors. I got both the CC and separator in my Summit White body color and they really stand out under the hood.
Definitely go with the ported TB. Very easy to install, especially if done when installing your CAI. You'll have to wait until you get your car though, because you'll have to pay a core charge that is refunded once you return your OE part. If you plan on leaving Fresno in winter, you will need a second set of tires. Since I live in the snow belt, I went ahead and got a complete wheel/tire/TPMS package from Tire Rack. I chose UPH A/S tires, not only for light snow but also to spare those soft summers from highway miles during summer road trips. I really like being completely independent of the tire shop. I don't have 1LE but I've read a number of threads where people have messed up the balance of the car by attempting to change the carefully calibrated setup. Stick with OE tires sizes, at least until you understand what direction you need to take the car after driving it for a while. Gills-this is one of the least expensive and easiest DIY mods. The monolithic side can use a touch of contrasting color. If you read through my journal below, you will find the long drawn out (and expensive) process I had. Hopefully, that will help you, not only with info but to pass the time.
Consensus is, by definition, a lack of leadership.
05-13-2014, 06:17 AM | #4 |
Tri-County Camaro SWFL
Mild2wild switch
Big worm taillight tint Gill inserts ZL1 splash guards are a must I hear that the Vmax ported TB is very worth it. Gives a feel like the car is faster but paired with a CAI gives the car a lot better throttle response.
05-13-2014, 01:11 PM | #5 | |
05-13-2014, 01:26 PM | #6 | |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
05-13-2014, 01:49 PM | #7 |
Check the tech tips on RevExtreme's website. In simple terms, the crankcase needs to be ventilated. On the LS3, GM does this by connecting a hose to the intake tract. The problem is, the vapors being ventilated are loaded with oily crap. I guess GM figures your combustion chambers make good incinerators. I like mine clean. So the catch can routes these vapors through a condensor taking most of the oil out of the fumes before returning it to the intake. It's simply a filtering system for the PCV.
05-13-2014, 02:34 PM | #8 | |
Drives: 2013 2SS/RS/1LE Join Date: Mar 2013
A lot of people say to do the clutch reservoir but check out the question by X25 in this thread:
http://www.camaro5.com/forums/showth...servoir&page=2 Quote:
05-13-2014, 08:16 PM | #9 | |
Sweet Annie!! BRM
Drives: '13 2SS/RS 1LE BRM NPP CF5 Join Date: Oct 2012
Plus Rapid Fire Tail Lights! Definitely put Xpel on all forward facing surfaces!
FGG60 - (BRM 2SS 1LE) 1 of 70!!
05-13-2014, 10:57 PM | #10 | |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
1st mod I did was the elite catch can. Please don't laugh, but the oil in the catch can, should I add it back into the engine. Looks clean and fresh( just did an oil change 400 miles ago) |
