11-07-2015, 10:40 AM | #1 |
Drives: Want a gen 6 Join Date: Jan 2013
ZL1 performance predictions
For the purpose of argument , lets assume it gets the same 640hp LT-4 variant as the CTS-V. It will also be Mag-Ride/NPP only like the last gen and full on 2SS only.
The new Z06 at 3530 lbs (MANUAL) 3558 (AUTO) lbs will run: 0-60: 3.1 (AUTO) 0-60: 3.3 (MANUAL) 1/4 mi: 11.1 (AUTO) 1/4 mi: 11.5 (MANUAL) The new CTS-V at 4140 lbs will run: 0-60: 3.6 (AUTO) 1/4 mi: 11.8 (AUTO) The C7 Z-51 manual weighs 3444 so about 90 lbs less than the Z06. Lets add the 90 lbs to the fully optioned 2SS weight of the C&D SS tested at 3760 lbs for a total of 3850 lbs for the ZLI. This would put it neatly between the CTS-V and Z06 in terms of weight. So ZLI predictions at 3850 lbs (AUTO) and 3825 lbs (MANUAL) are: 0-60: 3.3 (AUTO) 0-60: 3.5 (MANUAL) 1/4 mi: 11.3 (AUTO) 1/4 mi: 11.6 (MANUAL) Sound reasonable? Because a ZLI with specs like that will be world class! |
11-07-2015, 10:54 AM | #2 |
Drives: 2011 Camaro 2ss Join Date: May 2013
I think those numbers will be extremely close
11-07-2015, 11:15 AM | #3 | |
KaBoom1701
Your logic sounds good to me. I bet you'll be spot on if they make this new ZL1 6th Gen model.
Mods:
11-07-2015, 03:46 PM | #4 |
This also begs the question of whether or not adding an aftermarket roots blower like an E-Force might be a good option. IMO it may be a much cheaper and close to as good way to go. The only real difference between a roots modded SS and a ZL1 may be some styling queues and a warranty.
11-07-2015, 04:10 PM | #5 |
Drives: Current Camaro-less Join Date: Jul 2014
I think you're very close!
However I suspect that the weight is going to be closer to 3,900lbs for a number of reasons. The ZXX is almost certainly going to have 6 piston brakes out front and larger rotor 4 piston pieces out back, extra bracing, heavier half-shafts and maybe a larger, stronger diff and maybe a stronger driveshaft. So not a huge increase, but I don't think it'll only be 90lbs heavier. Even at 3,900lbs it'll still be 200+ pounds lighter than the current ZL1. |
11-07-2015, 04:22 PM | #6 |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
I still say it will be a 396 S/C with 800HP
What ever it will be it has to up the Hellcat 700HP. |
11-07-2015, 09:18 PM | #7 |
Drives: 2013 Camaro ZL1 convertible IOM Join Date: Feb 2008
11-07-2015, 11:41 PM | #8 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
There's a vocal crowd that takes no pleasure in a Camaro that outperforms the Hellcat, and only care that the HP is greater than 707. I have yet to understand this concept, but for many HP is all that matters.
2017 SS 1LE | HBM | Vortech V3-Si supercharger (620RWHP and 575ft lbs) | PDR | Black Bowties | Illuminated Front Black Bowtie | Illuminated Door Sills | Smoked Tails | vented seats mod
11-11-2015, 11:45 PM | #9 |
HP sells cars torque wins races!
11-12-2015, 10:23 AM | #10 |
Casey Woodside
Drives: a very fun car Join Date: Jun 2010
Shop in Texas just got a 2016 SS with out magnetic ride and it was 3645 they said it had 7/8 tank of fuel. 3900 would be a really good guess for the next Z. That will kill a hellcat in every thing. Hot rod magazine had to SS at auto club drag way. The auto was at 12.2 in the quarter mile.
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w |
11-12-2015, 12:27 PM | #11 | |
Drives: 2018 ZL1 1LE, 1969 Nova SS 396 Join Date: Aug 2014
The only reason the Hellcat has so much hype is because of the hp number. It took my Dad a full year to get his hellcat at msrp. All these idiots paid 10-20k mark ups and bought into the hype, some people even bagged there car thinking it would somehow go up in value. By the end of 2016 Dodge predicts there going to build over 9000 hellcats!! Thats more than all the ZL1s produced over the last 5 years
18 ZL1 1LE|M6|Nav|PDR|CF Hood|CF WING|CF Dash|Tow Hook| |
11-12-2015, 01:18 PM | #12 | |
Drives: Trans am Join Date: Jan 2015
11-12-2015, 02:41 PM | #13 |
Drives: 2018 ZL1 6M, Silverado High Country Join Date: Oct 2008
If the next ZL1 or Z28 whatever they call it gets the LT4 with at least 640hp and weighs around 3900lbs it will be a very close drag race with the hellcat. It definitely will eat it's lunch on the racetrack. Hopefully early next year we will know.
Previous Camaro's - 2002 Z28 6 spd manual, T tops, Sebring Silver - 2010 2SS 6 spd manual, Cyber Gray Metallic
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof 2019 Silverado High Country, Daily Driver |
11-12-2015, 05:42 PM | #14 | |
Drives: GM Join Date: Sep 2010
Roto- Fab Cai, SLP 1 3/4" headers, 3"X pipe, LM2 cat back, Comp Cam & AI Heads, SLP UP, RPM Tuned, GPI Intake, Vmax TB, ADM Air Scoop, 3.91 Gears, Gforce driveshaft, Braille 21#, Elite Catch Can, Pfadt Tie Rods, Diff Bushings and Trailing arms, Eibach spings & sways, BMR cradle bushings, Nt555r's.
