07-14-2018, 09:11 PM | #1 |
USA-1
Do I need to do bushing timing if I'm not droping the car?
Hey all,
So I'm hoping to install my 1LE rear shocks/ZL1 rear sway bar on my 2010 SS tomorrow, but I'm not sure if I need to time my bushings or not. Is this a thing for lowered cars only, or should I do this with mine tomorrow? I don't have access to a lift and this will be done on jacks/jackstands.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
07-14-2018, 09:15 PM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Nope... not necessary.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
07-14-2018, 09:22 PM | #3 |
USA-1
So, just want to make sure here, but I'll be replacing my rear lower control arms and end links with the newer versions to accommodate the ZL1 rear sway, still no reason to time the bushings?
07-14-2018, 09:51 PM | #4 |
Drives: 13 Camaro Join Date: Oct 2016
Yes anytime you loosen those bushes, stock, lowered doesn't matter you must clock the bushes.
07-14-2018, 10:02 PM | #5 |
USA-1
Oh boy, now we have conflicting advice... (
07-15-2018, 03:10 AM | #6 |
Drives: 2010 CGM 2SS/RS M6 Join Date: Jan 2016
The last time I was in that situation, I didn't know anything about timing the bushings. I don't doubt that it should be done, but my experience was that not doing it had no effect.
Sent from my SM-N950U using Tapatalk
2010 CGM 2SS/RS M6 - Comp 227/243 .620/.612 | Nitrous Outlet Plate Kit - 100 Shot | ARC Bottle Bracket/Heater | NOS Progressive Controller | AEM Wideband | Kooks 2"x3" LTs | 3" Custom Catback | CAI Intake | Bo White PTB | Billet Motor Mounts | Hurst Short Throw | McLeod RXT | RAM TOB | 3.91 W/ Eaton Truetrac, LPW Cover, Poly Bushings, GForce 850HP Axles | Eibach Pro-Plus Kit | Whiteline End Links | Hotchkis Tower Brace | ZL1 Front End | Blue Powder Coated Calipers | Vorsteiner V-FF 101 - 20x11 and 20x10 | M/T Street Comp - 305/35 and 275/40 | 2 JL Amps | Diamond Audio Speakers | JL Stealthbox
07-15-2018, 02:21 PM | #7 |
Drives: 2010 2SS/RS Join Date: Dec 2009
It loads the suspension part if don't clock them and if your doing the control arms at a minimum you should clock them.
Orange Krush II
07-15-2018, 03:32 PM | #8 |
USA-1
Too late, I installed everything this morning. I need to get an alignment, but it feels okay so far.
07-15-2018, 04:20 PM | #9 |
Drives: 2015 Z/22 Join Date: Aug 2015
If you still need to get an alignment then that would be the best time to time/clock the bushings. Ask the mechanic to time the bushings and hopefully he'll know you mean, if not then basically he just needs to loosen the bolts for the bushings in question and jounce the car (or drive off the rack slowly and back on) then tighten up the bolts.
07-15-2018, 05:31 PM | #10 |
Your initial post says sway bar and shocks... I don't see any reason to clock bushings. If you change arms or other suspension components... yes, you should.
07-16-2018, 03:45 PM | #11 |
USA-1
It sure does, but to install a ZL1 rear sway on a 2010 you need the newer 2012+ style rear lower control arms.
