Old 08-26-2016, 12:29 PM   #1
sdmaro
Drives: 2011 LS Camaro
BC coilovers installed
Just wanted to share some early pics. Still needs to be detailed....
Exhaust: Magnaflow catback/x-pipe, Injen SRI, BBK Headers w/ no cats
Suspension: BC BR Coilovers
Cosmetics: ZL1 front conversion, AAC plasma afterburners 2.0, GFX rear,
Interior: AAC red footwells, ZL1 shifter boot/knob, suede center console
sdmaro is offline   Reply With Quote
Old 08-26-2016, 12:42 PM   #2
Gixxer 1000
Gixxer 1000
Gixxer 1000's Avatar
Drives: 2012 Camaro 1SS M6
Looks good, how is the ride?
Gixxer 1000 is offline   Reply With Quote
Old 08-26-2016, 01:58 PM   #3
sdmaro
I believe I have the dampening set to halfway and I'm still experimenting with it. But so far so good!
Old 08-26-2016, 02:07 PM   #4
Gixxer 1000
Gixxer 1000
Ok I'm thinking about getting that brand of coilovers, I'm on Pfadt springs now but want that adjustability of coilovers.
Old 08-26-2016, 02:38 PM   #5
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
Looks nice! How much did you lower it by?
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
Old 08-26-2016, 05:12 PM   #6
sdmaro
2inches
Old 08-26-2016, 05:20 PM   #7
hesster
hesster's Avatar
Drives: '10 C5 SS, '77 Bandit T/A
I found that setting them too low made more noise and were "clunky". Mine are ER's and set at Frt 15/10 and Rear 16/12, and will prob add even more to the front since I have a Whipple (more weight). Ride is excellent, and love the ability to get perfect ride height. Not to mention that there is lots more headroom to set them in the 20ish range for serious handling.
hesster is offline   Reply With Quote
Old 08-27-2016, 04:09 PM   #8
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Op, becareful of going to low. Below 26" as measured from the lower wheel rim to the fender arch in the rear, can cause strain on the axels and possibly failure or leaking at the boots. Normal driving may be ok but not for any kind of handling. Basically 1" drop is ok
VR Baron is offline   Reply With Quote
Old 08-28-2016, 12:05 AM   #9
sdmaro
I'll measure it tomorrow. usually just cruise in this car.
Old 08-28-2016, 01:13 AM   #10
Synner
Drives: cars
The ER's are a great shock, very underrated on this forum. You'll enjoy them.
Old 08-28-2016, 10:04 AM   #11
VR Baron
VR Baron's Avatar
also what happens is the lower you go the upward travel of the rear arms is reduced. Only have 3" of travel up or down.
coilovers, slammed
