01-30-2019, 09:58 AM | #1 |
New Purchase
I just recently purchased a 2013 Camaro SS. It has been lowered and has adjustable coil overs and has an adjustble ride height. I have been trying to understand all about these things since I never had to before. It looks like the car sits about 25.5inches from the lower wheel lip to the fender which would be roughly around 650mm. Ive read on here 660mm is where it should be. Is it going to hurt anything that its sitting lower than recommended? If so, how would I adjust it higher and what all would I have to do? What does the adjustments under the hood and in the truck do vs the ones on the shocks etc? Thanks in advance.
01-30-2019, 01:49 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
The adjustment knobs under the hood and trunk will be the compression and/or rebound adjustments for the coilovers. The Camaro can handle a drop of about 1.5" or so before needing to compensate with other suspension mods (bump steer kit, etc.). When adjusting ride height you just need to make sure that all relevant suspension bushings have been timed, clocked, reset - whatever you want to say... I'll let you read up on that . If you haven't had an alignment done you may want to considering doing so, and at the same time have the bushings timed; if the mechanic doesn't know what "timing" bushings means then perhaps find another mechanic.
01-30-2019, 03:30 PM | #3 |
The car was already lowered when I purchased it. I am really just wanting to make sure it being only 25.5in is OK and not going to dmg any other parts of the car. Id assume the previous owner got an alignment done.
01-30-2019, 03:53 PM | #4 |
Drives: 2011 Chevrolet Camaro LS Join Date: Jun 2018
Lowering the car will not hurt it assuming the supporting mods have been done. I'm currently on a 1.5" drop and I haven't damaged anything. I would be cautious of inclines, but besides that you are fine. I'd also recommend checking the exhaust to make sure it isn't super low hanging. While you're under there, check for any scrapes. As far as adjusting the height, you have to remove the wheels and on the coilover there will be threads and one way is raising and other lowers it. There are plenty of videos on YouTube on how to adjust coilovers. The hood ones are for dampening, as previously stated.
Best of luck, and congrats on buying a great car!
"If you aren't first, you're last" -Ricky Bobby |
01-30-2019, 04:00 PM | #5 |
Thanks for the replies. I am not sure what other mods may have been done or not done. The only time I have scrapped the bottom is on a weird hill transition. Other than that I have not. It seems to ride pretty smooth other than slight vibration at around 75mph. I know over all a CAI was put on as well as the coil overs, and adjustable ride height, cat back solo exhaust and rims. This weekend Ill be adding a catch can to it and cleaning the TB up. At least now I know nothing is going to break under there for stress or anything for being too low lol. Thanks again.
01-30-2019, 05:05 PM | #6 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
pics please!
01-30-2019, 06:01 PM | #7 |
Ill have to try and get a pic or two tomorrow. Its dark now. Over look the dirty too. I washed her this weekend and something was burning down the way and got ash all over her. Needless to say she needs another bath. lol
01-31-2019, 05:58 AM | #8 |
Was just thinking that an alignment/bushing timing may be a good idea since you may not know if the previous owner did those, just to be safe...
01-31-2019, 06:55 AM | #9 |
01-31-2019, 05:40 PM | #10 |
Here are a couple of images I took today.
01-31-2019, 08:39 PM | #11 |
Previous owner said all that was done. So guess Im good to go there then lol. He took real good care of the car for sure.
01-31-2019, 10:54 PM | #12 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
660mm for the rear is as low as you should go if you plan on any track or autocross use. At high speed below that the axle angle is not good. Heat builds up, the axle grease liquifies and comes out of the boot. Bye bye axle. If you do roadcourses or strip I wouldn’t even go lower then 675. For the street your fine at 660. And by the way 660 is 1.5” from max stock which is 700 mm. Stock I was 690. I keep it at 665 as I autocross. To maintain stock rake front should be 10mm less then your rear dimension.
02-01-2019, 06:23 AM | #13 |
I do not go to the track or do autocross. I havent driven over 100mph in years. I guess it depends on what youre calling "high speed" too. If youre talking long durations of 150mph+ then I guess I should be safe at 650mm. If youre talking over 80mph then I may have an issue.
02-01-2019, 07:09 AM | #14 | |
Thread Tools | |
