05-08-2018, 09:49 AM | #1 |
YUDLOSE
Drives: Supercharged 2010 ABM 1SS Join Date: Aug 2011
Need help with OEM ZL1 wheels
I recently put on a set of oem zl1 10 spoke wheels on my car. ITs a 2010 SS Camaro. 20x10 front and 20x11 rear with brand new Nitto NT555 G2 tires. Front are 275/40/20 and rear are 315/35/20. I am having an issue where the driver front tire is rubbing but no issue on passenger side. I guess its due to me being on that side. I am not sure if its the fender or inner fender but it has a few knicks in the tire. I am lowered on pfadt 1.25 springs. I ran this same tire size on my last setup but was the Nitto Invo tires instead but the rims where 20x9 front and 20x10 rear. I am trying to see if anyone has any suggestions on what I can do or if anyone else has had this issue and what you ended up having to do to fix it. I really don't want to buy another set of front tires if I do not have to. Any help is appreciated.
Thanks.
Trey Jenkins 2010 Supercharged ABM SS Camaro LS3 #400 Order Number: NJGC85 Build Date: 06/24/2009 1996 Blue Z/28 Camaro 396 stroker in the process 1994 Red Z/28 Camaro |
05-08-2018, 11:10 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
What are your camber settings? Might just need a bit more negative camber; you can get away with -1.0° or even a bit more, closer to -1.5° without sacrificing tire wear. I believe those tires also have a harder inside edge to compensate for tire wear due to negative camber.
05-08-2018, 12:39 PM | #3 |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
My drivers side rubbed when I had 275-40’s on 20x10+23 ZL1 reps up front. A +23et is standard for the ZL1 and 1LE, but they run the lower profile 285-35-20, which does not rub. I went with 285’s and have no problems. Handles and looks better. I’m down 1”. At AutoX the 275’s were getting cut slightly because of the sharp inner lip. If you plan on keeping the tires I would have the inner lips rolled. I had a -1.2 camber and it did not help. You may be able to live with it if it is not cutting the tire. Any type of HPDE will flex the taller side wall on the 275 and rub. Good luck.
05-08-2018, 12:52 PM | #4 | |
YUDLOSE
05-08-2018, 01:07 PM | #5 |
A 275-40-20 is 28.66 in diameter. A 285-35-20 is 27.85 in diameter. You are .25” lower up front than mine. I AutoX and canyon carve with MPSS’s. And yes, too much deviation from front to rear will create a problem. GM designed the ZL1 and 1LE with the lower profile tires and the wider offsets for better handling and no rubbing.
05-08-2018, 01:18 PM | #6 |
GPI Sales Consultant
My buddy runs that exact setup on his 1LE without trouble. He's lowered an inch. Interesting that you're having that. Agree with the suggestion to see if an alignment with more neg. camber will get you the clearance you need.
Got a question about a GPI product? Feel free to shoot me a message! |
05-08-2018, 01:27 PM | #7 | |
YUDLOSE
or should I take it back to tire shop and see if they can add some negative camber and see if that helps.
05-08-2018, 01:54 PM | #8 |
YUDLOSE
could be the .25inch difference idk.
05-08-2018, 02:02 PM | #9 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Running 285 up front with a 10 inch wheel with the Nitto G2s no issues but I'm not lowered either.
Orange Krush II
05-08-2018, 02:58 PM | #10 |
'It's an experiment'
285’s up front 10", lowered 1" no issues...
-Don
747 RWHP 794 RWTQ
05-08-2018, 03:46 PM | #11 |
05-08-2018, 03:47 PM | #12 |
05-08-2018, 03:50 PM | #13 |
I think the Michelin is slightly wider than the Nitto. Mine do not stick out.
05-14-2018, 12:33 AM | #14 |
BowtieBelle's SS
Drives: 2010 Camaro SS Join Date: Jan 2012
Chasing the same issue. I can’t camber more with my coil overs. So either going to raise them a bit or get spacers and camber more.
