04-07-2018, 10:06 PM | #1 |
US Veteran
Drives: 2011 Silver Ice Metallic 2SS/RS A6 Join Date: Jan 2011
Tuned 2011 SS threw code P0336
My 2011 SS/RS has just over 60,000 miles. It has been a garage queen for the last few years. I keep it on a battery tender and probably don’t start it as much as I should. It is tuned by Jannetty, headers, exhaust, and CAI for performance stuff : that’s the history.
The only recent thing I’ve done was got a used rim/wheel because I had one that was bent. I put it on, took a spirited drive and came home. I stopped in the driveway turned it off and let it sit for a few minutes. Got back in to start it and it didn’t want to start, at first it just wouldn’t fire, then it seemed like a weak battery. Threw all kinds flashy dash lights, stabilitrack and all nannies stayed lit but it did eventually start and I backed it into the garage. I checked codes a while later and only P0336 was there. Battery is the original one, gas may be bad?, and that’s all I can think of. Hoping this isn’t something serious. I’m going to get a new battery next week. Any thoughts that may help? Thank you!
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS) |
04-07-2018, 10:17 PM | #2 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
I would attempt replacing the battery first. 6/7 years with original is pushing it no matter how well maintained. Low voltage issues in the gen5 is notorious for causing a variety of electrical issues. Good luck
04-08-2018, 07:48 AM | #3 |
Drives: [COTW 8/3/15] 2010 Camaro SS L99 Join Date: Mar 2015
It’s the battery, mine did the same thing when the battery was going bad..
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable! https://www.camaro5.com/forums/showthread.php?t=418273 |
04-08-2018, 08:56 PM | #4 |
US Veteran
Thanks for the replies folks! I'm betting on the battery also and that was my first thought; just wanted to be sure and get some others' advices and experiences.
I'll post back with my experience.
05-13-2018, 04:43 PM | #5 | |
US Veteran
Battery was the issue. All good now. Sent from my iPad using Tapatalk
Tags |
p0336 |
