Old 02-10-2021, 10:15 AM   #1
caper
Drives: 2010 IOM 2ss/RS
HF cats
i know there is issues with them failing on SC cars, are they ok to use on a turbo car? i have the turbonetics kit that reroutes the exhaust back up to th turbo after the cats.
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 02-10-2021, 12:40 PM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Turbos can be worse than a blower. Cats don't like anything that will send a boatload of fuel at them. You might be ok if you stay around 8 pounds and don't run the AFR down to 11.5:1 very much.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
Old 02-10-2021, 12:57 PM   #3
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
Aside from carb compliance. the main reason they route after the cats to the turbo is probably because the turbos become a choke point and create more heat. Cats don't like crazy heat. The cats also will cause back pressure leading back to the turbo causing more heat etc.
Ask any Subaru owner about cats and aditional boost lol
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 02-10-2021, 01:14 PM   #4
Vegas Bound
Drives: 2013 Sparkly Red One
Get ultra high flow cats, gut the suckers.
Vegas Bound is offline   Reply With Quote
Old 02-10-2021, 01:48 PM   #5
RupertPupkin
Drives: 2014 Camaro SS 1Le
HFC... what are those?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 02-10-2021, 02:58 PM   #6
Vegas Bound
Hydrofluorocarbons.
Old 02-10-2021, 05:12 PM   #7
caper
i only want them so that i can pass the OBD11 car readiness to get smoged. i have no cats right now and no CEL because of the tune, but the OBD11 will show sensor not ready when they scan it. i can put my stocks back on for the test and remove them, but i am would like something more permanent so i dont need to keep swapping ad tune etc.
Old 02-10-2021, 07:49 PM   #8
RupertPupkin
Originally Posted by Vegas Bound View Post
Hydrofluorocarbons.
Damn you internet, and your inability to project sarcasm.
730whp: 630Trq
Old 02-10-2021, 08:12 PM   #9
Vegas Bound
Exactly, my response was sarcasm.
Old 02-10-2021, 09:08 PM   #10
RupertPupkin
Lol
730whp: 630Trq
Old 02-11-2021, 06:41 AM   #11
Vegas Bound
Lol
And I thought it was a made up word. Apparently it is not. I just had my HVAC system replaced, that is probably why it was in my head.
Old 02-11-2021, 08:04 AM   #12
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Just gut em and be done.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
Bildo is offline   Reply With Quote
Old 02-11-2021, 08:11 AM   #13
caper
wouldnt that have them throw codes, or i'll have to tune the sensor to not read - either way itll not pass the OBD11 test....or am i wrong?
Old 02-11-2021, 08:26 AM   #14
Bildo
Bildo's Avatar
I don't have em on mine but I also don't have any sort of inspections in my state.... The rear 02 sensors can be turned off easily in the tune.
