09-04-2014, 11:04 AM | #1 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Painted rotors
I apologize if this seems dumb, but can the rotors be painted? I'm not talking about the surface used for braking, but rather the rest of the rotor. The example below shows the difference between unpainted and painted. The Stillen rotors I'm interested in buying look like the ones on the right, but I'd like to add the black accents (edges, center hub, slots/dimples). I have done a full chrome delete on my car and the only "shiny" metal left are the rotors and I want to minimize that.
The only ones that I've found that look like the ones on the left are "pre-painted" from the supplier, but in this case isn't possible. I still want quality rotors, I just want to update the looks. Any suggestions for doing this? Here's an example of the difference:
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
09-04-2014, 02:01 PM | #2 |
Drives: 2014 2ss 1le Join Date: Sep 2011
I have seen guys just spray paint the whole thing. The pads will take off the paint on the brake surface right away and now the rest wont rust.
09-04-2014, 02:19 PM | #3 |
Drives: 2011 Red 2SSRS A6 Join Date: Jan 2011
Yes you can, people on here do it all the time because you can see some rust on the older rotors.
MPD1 Z Force hood, 1LE splitter, ZL1 rockers and diffuser, Heritage grille, Sparks Restorations emblems, Magnuson Supercharger, ID850 Injectors, Alky Methanol Kit, Livernois Fuel Pump Roto-Fab CAI, SW long tube headers, CNC ported throttle body, High flow cats, Lethal Racing Prowler Cam, LS3 conversion, Yank 3400 Stall, Corsa 3" cat back exhaust, RX Catch Can, BMR Suspension, BC Coilovers, Slotted and Cross-drilled rotors, Custom Interior.
09-04-2014, 02:30 PM | #4 | |
2010 2SS/RS M6
Or would the paint not really effect the new pads?
09-04-2014, 02:33 PM | #5 |
Drives: 2013 2SS 6M Join Date: May 2013
really?
Strut tower brace(GM), CAI, Blade Spoiler, ZL1 wheels and tires, Heritage grill, Dual mode exhaust, and thats it, no more..except for the lowering springs..Ok Hotchkis springs were delivered today, thats it..
09-04-2014, 02:37 PM | #6 |
2010 2SS/RS M6
09-04-2014, 02:39 PM | #7 |
I've done this on past vehicles.
A couple of ways to going about it. Mask off the rotor friction areas, paint the whole thing and "run" off the paint with old pads (I would not advise this method) or painting the whole thing and then having a good brake shop turn the rotors to strip the paint off. I would highly recommend the masking method over the others!
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903 ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | DRL harness | RX Catch Can | Mini me Cortana: 2015 Harley Davidson Road Glide Special V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer | Klock Werks 12" Pro-Touring windscreen Own an Aqua Blue Metallic Camaro? Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros! |
09-04-2014, 02:40 PM | #8 |
If I were doing it, I would probably take that route. I doubt the paint will affect the pads, but I would do it that way just to make sure. I've got the Stillen rotors and they are awesome, and my painted calipers are coming in today. Good luck
09-04-2014, 02:45 PM | #9 |
2010 2SS/RS M6
Normally I would just tape off the friction surface and paint the inside hub area and outer fins, but I want to highlight the holes/slots too. Kinda hard to tape off around all of that.
I've found a few youtube videos with the how to, but none of them address dimples/holes/slots.
