Old 11-12-2014, 10:41 AM   #1
strtsol1109
Drives: ZTS pearl in autoflex
V6 clutch kit
What are you guys all going with? Mines starting to slip, but doing some research I can't really find anything but oem...
Full MBRP 3in exhaust, Vitesse TC, BBK LT, black iceolator, VMAX TB, vararam, LG coils, zl1 reps, zl1 front bumper, zl1 grille, zl1 rockers, CF Copo hood, CF trunk, gm blade wing, HAVOC diffuser, APR splitter, dipped SS calipers
strtsol1109 is offline   Reply With Quote
Old 11-12-2014, 04:14 PM   #2
crc91
crc91's Avatar
Drives: '14 1LS
I believe ram clutches are pretty good however I have no experiance with them myself. I've heard mix reviews on the spec clutch kits. I don't think to many v6ers are using aftermarket clutches. You may even wanna contact monster clutches. They seem like they REALLY wanna out something out for the v6 problem is there's is gunna be too of the line and made to handle high hp which'll cost more $$$ however the stock unit is probably just as pricey. Hopefully more aftermarket clutch owners will chime in soon. But I'd say for the v6 ram is probably the leader.
crc91 is offline   Reply With Quote
Old 11-12-2014, 04:26 PM   #3
crc91
crc91's Avatar
Drives: '14 1LS
Actually I just found this
http://www.superchevy.com/how-to/tra...tem-v6-camaro/
You may recognize that supercharged v6 too! Might want to send sycraft a pm and ask how his experiance with RAM clutches is going as usual he's the guy to go to.
Old 11-12-2014, 06:12 PM   #4
strtsol1109
Can't find spec for the llt platform, don't really wanna spend 1000 on a 900ftlb clutch when my car won't see a third of that lol. The oem just wears out so fast...
Old 11-12-2014, 08:12 PM   #5
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
I have the Ram dual disc part nr.(75-2105) and love it.
gutterball is offline   Reply With Quote
Old 11-13-2014, 12:42 AM   #6
crc91
crc91's Avatar
Drives: '14 1LS
Cool can you give me more details about it? Like how long have u had it now is it worth it over oem? Is it noisy? Really stiff? Lighter? Heavier?
Old 11-14-2014, 12:30 AM   #7
gutterball
gutterball's Avatar
It's slightly stiffer than normal, but not bad at all, have had it now for about a year. I like it. My original clutch didn't look all that bad, but it definitely was slipping. Their number is 803 788-6034
Old 11-14-2014, 12:47 AM   #8
crc91
crc91's Avatar
Drives: '14 1LS
Awesome man. Thanks have you used it during a open track day or anything?
Old 11-14-2014, 10:14 PM   #9
gutterball
gutterball's Avatar
Not yet, but I have gotten it to it pretty good.
Old 11-14-2014, 11:17 PM   #10
sycraft
COTW 5/06/2013
sycraft's Avatar
I love mine and track it quite often, been holding up great and butter smooth engagement, I had a guy drive my car and love the setup, he is a calibrator at a local shop. I have had mine for over a year, it was the first production unit, Gutterball probably got the second. We both push the limits of the drivetrain and no hint of wear, holding strong. a little noise at times with the clutch pedal depressed, all twin discs do this to some extent. engagement is smooth and consistant
Old 11-14-2014, 11:58 PM   #11
crc91
crc91's Avatar
Drives: '14 1LS
Well it's settled I know what I'm getting when mine goes. How much more is te ram kit vs oem replacement?
Old 11-15-2014, 12:04 AM   #12
sycraft
COTW 5/06/2013
sycraft's Avatar
since you get everything, including flywheel, around 1100 I think...
Flywheel is quite a bit lighter too, revs faster...
Old 11-15-2014, 12:32 AM   #13
crc91
crc91's Avatar
Drives: '14 1LS
Awesome that's just what I was hoping to find wen the time comes. Speaking of which at near stock power levels with a little bit of spirited driving how long should the stock clutch last me?
Old 11-15-2014, 08:17 AM   #14
sycraft
COTW 5/06/2013
sycraft's Avatar
No Idea, I've been boosted since 3K miles..... some as little as 30K some more than 100K. Depends on driving habits..
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
