Old 10-21-2019, 05:08 PM   #1
B.mik
Drives: 2010 LLT RS
Too much oil?
Hey guys, my dad took my 2010 v6 for an oil change(without telling me) and the guy dumped 6.5 liters in the engine, should i be worried?
B.mik is offline   Reply With Quote
Old 10-21-2019, 06:47 PM   #2
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
I would say check the dipstick while the car is on a level surface and the engine is off. If it's over the full mark, don't start it until the proper oil level has been established.
6.5 liters is almost 7 quarts.
FasNuf is offline   Reply With Quote
Old 10-23-2019, 03:10 AM   #3
B.mik
Drives: 2010 LLT RS
Yeah the dipstick shows like 1 cm extra oil, is there anyway i can siphon or suck the extra oil? I am currently in the village house and i don’t have my jacks.
Old 12-09-2019, 03:26 PM   #4
'10CamaroDude
Drives: 2010 Camaro LS
Being 1 quart over won't hurt. The problem is when there is too much oil and
the crankpin journals are bashing into it when the crank is spinning.
IF you can get a tube down the dip-stick hole, you can pneumatically pump it out.
Other than that, well, then the messy solution; pull the drain plug, then put it back
in after you got about a quart out of it.
'10CamaroDude is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
