Old 09-04-2021, 08:37 PM   #1
nicholasp
Drives: 2012 Chevy Camaro 2SS
Tuner Recommendations
Can anyone recommend a tuner in the Tampa Bay area? I am working on putting my Whipple on and supporting mods, so will definitely need a tune afterwards.
Or, who can point me in the right direction to get started on using HP tuners myself?
nicholasp is offline   Reply With Quote
Old 09-04-2021, 08:42 PM   #2
C@mero
Drives: Camaro 1LE
Pat G if you want remote.
C@mero is offline   Reply With Quote
Old 09-04-2021, 08:51 PM   #3
Mlgprodriver
Drives: 2010 Camaro 2SS RS
Man I would not even play with HP tuners unless I had at least a years experience. You start playing with a cars fuel trim and you can easily blow the car up if you don’t know what you are doing. I would use google to look for good speed shops and pricing. But pay most attention to the reviews! Just my $0.02
Mlgprodriver is offline   Reply With Quote
Old 09-04-2021, 09:34 PM   #4
C@mero
Drives: Camaro 1LE
You can data log, and send that to the remote tuners/ post up here. A lot of knowledgeable guys. Agree with driver…if you’re a novice, dont touch anything. Smal problem could be catastrophic.
Old 09-05-2021, 02:58 AM   #5
Mlgprodriver
Yup, in my opinion... tuning is an absolute work of art.
I can’t even begin to understand how that’s done. However, I did all the work on my engine myself. Car work is easy, tuning = a brain like Einstein.
Old 09-05-2021, 08:40 AM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Check out Phil at Tampa Tuning, he has done a few Camaro's from my area. He's pretty good from what I hear.
TSP STAGE 3 CAM,231/246 @112 LSA 614/641 LIFT, CIRCLE D 5C-4200-4500 CONVERTER,LOD INTAKE.CORSA EXHAUST. DSS 1 PC DS. PEGASUS SOLID CRADLE MOUNTS. 486RWTQ/475RWHP.LOTS MORE.
Old 09-07-2021, 07:01 AM   #7
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Phil is an honest guy too. I talked to him about my car years ago and he said I really should find someone local and do a dyno tune rather than just selling me the services he offered.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, and meth. Z28 suspension.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff.
Old 09-07-2021, 12:54 PM   #8
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Jannetty Racing. They know those whipples like the back of their hand. Ted can remote tune.
Greenhornet2 is offline   Reply With Quote
Old 09-07-2021, 04:02 PM   #9
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Fasterproms is in the area there and I would HIGHLY recommend Jeremy. He did the first tune on my car before I moved away from where he tunes. If I still lived near where he tunes I would have another one of his tunes on my car in a heartbeat.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 09-07-2021, 06:35 PM   #10
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
Check this website
https://goatropegarage.com/
And this youtube channel
https://m.youtube.com/channel/UCP_LcnBKwJqJOiGoCRT5SCw
He also does a live question and answer on YouTube 7pm on Thursdays
Don't check him out if your not serious about wanting to learn hptuners.
Tuning is an art but you can learn how to do it if you take your time and baby steps, a wide band is a must if your going to do actual Tuning.
Hptuners is personal favorite.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans
Tarendor is offline   Reply With Quote
Old 09-07-2021, 10:48 PM   #11
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Ted freakin jannetty and dont look back. See my setup in my sig and he remote tuned it perfectly. I cant recommend him enough
15 Camaro SS- GPI max top end, ESS Vortech V3 10psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 09-08-2021, 10:48 AM   #12
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
Jeremy also tuned my 2010 SS with an Edelbrock S/C on it. He also tuned my C6 Corvette. He did these tunes in PA, where he comes 2-3 times a year to tune LS motors.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 09-09-2021, 09:17 PM   #13
nicholasp
Fabulous data, thank you all.
Next (possibly inexperienced) question is: I will be putting on a swath of mods at one time which, theoretically, will not be safe to run without a tune beforehand. What is the protocol here? If I bring it to a place, can I lightly drive the car with a new blower, injectors, fpcm, etc. or is this potentially a disaster? Flatbed over?
Re email tunes: I would need to purchase HP tuners equipment beforehand so that I can even load the file, correct? Or can these be sent and uploaded using plug and play type tuner, say a bullydog for example?
Old 09-09-2021, 09:28 PM   #14
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Flat bed it to the tuner , don't waste money on a programmer, the dyno tuner dont need that he uses a laptop
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
