09-12-2021, 03:11 PM | #1 |
Drives: 2012 Camaro 2SS Convvertible Join Date: Sep 2021
Rally stripe color ideas needed
Hi all, could use some ideas on what color stripes to put on our 2012 convertible 2ss, only thing wife and I can decide on is style of stripe, both want rally. It's black with a buckskin top and beige leather interior, want somthing that adds to black when top is down but not too gaudy. Thanks
Also, your suggestions on a great paint shop in southern wisconsin or norther Ill. would be appreciated, Thanks agian.... |
09-12-2021, 04:48 PM | #2 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
A med dark silver could work , but black on black might be the way to go , semi gloss or satin black , not flat tho will look cheap on a gloss black car
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
09-12-2021, 05:18 PM | #3 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
maybe you should try it in vinyl first,if you dont like it you can remove it that way.
09-12-2021, 05:59 PM | #4 |
I agree with the black on black, kind of a ghost stripe, also a good idea to try vinyl first. Thanks for the ideas!
09-12-2021, 06:02 PM | #5 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
what davidscamaro said and if you want to go flash - bright yellow.
Next door neighbor has a black Hellcat, he had it double rally striped hood and trunk in yellow and did the hellcat badges yellow. It looks pretty good! |
09-12-2021, 06:12 PM | #6 |
I would like that if we had a black top.
09-12-2021, 11:53 PM | #7 |
Drives: Camaro SS Join Date: Mar 2021
As Dave said, I was thinking a non-glossy black.
09-13-2021, 05:44 AM | #8 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
If you are going with paint get some chip samples. You might find a color that will grab you. I was thinking a light champagne but not sure if that would go with your top.
09-13-2021, 01:21 PM | #9 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
With the brown top I'd go with a brown stripe. Here is one example to help visualize, I realize it might not the the perfect shade or stripe style but helps to see an example on a car..as you consider what you want.
https://www.classicindustries.com/pr...s/g149335.html This might be too orangish so here is a more brown color on a mustang model too |
09-13-2021, 02:17 PM | #10 |
Drives: 2010 2SS/RS, VR ext/Blk Int Join Date: Jul 2012
I'd go with a matte black stripe or even ghost stripes. Subtle but adds some pizzazz as my dad would say.
09-14-2021, 08:11 AM | #11 |
Thanks for the great ideas, that helps!
