Old 08-30-2012, 08:23 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Well I was going to spray but....
Well ive been so unsure what kinda mod I wanna do next. I was rolling around lowering the car or getting the Vmax. Well I got bored at work was looking up NOS kits. Well it seemed ZEX was the way to go. After doing some reading on ZEX's website they say not to use the kit if the car has already been tuned or not to use the stock plugs on a shot above 55. Well I wanted to run 75 on the street and 100 at the track. changing the plugs would be no issue. I would run my stock plugs untill I feel im going to be spraying then I would switch them out. The tuning on the other had seems like a pain in the ass. I would need 3 tunes it seems like. One for what im using now, two for the 75 shot, and three for the 100 shot. Seems like a pain in the ass just for a few seconds of fun.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 08-30-2012, 08:28 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Umm.... where did you read that?
The fastest v6 on the planet... Member HDRS runs a 125 shot and isn't even tuned.
Old 08-30-2012, 08:30 PM   #3
Juiced1
Drives: 2012 2SS CAMARO 45th
Most nitrous kits are designed to work with the factory tune. The problem you would run into is with timing. Most tuners or after market tunes advance timing which is a bad thing for nitrous (not safe). So returning your car to the stock tune is a good bet. As for the plugs, make sure you run a non paltinum plug. A NGK plug generally works great with nitrous or without so they are generally a good bet. Grab a Zex kit and you won't regret it. We carry them with free shipping! Give us a call if you have any other questions!
Juiced1 is offline   Reply With Quote
Old 08-30-2012, 09:07 PM   #4
2010_camaro
I read this from ZEX's website.
Old 08-30-2012, 09:11 PM   #5
2010_camaro
I can buy the plugs no problem. How will the ZEX system really work with my car and its mods? I have a trifecta tune. I can turn it back to stock but wont I be Fu*king my self over all with running a modded car stock tune and 100 shot?
Old 08-30-2012, 09:37 PM   #6
lscamaro
lscamaro's Avatar
Or you could just ask Vince for a nitrous tune? The reason for no tune is because of the timing advance from the aftermarket tune. When you get a nitrous tune, you retard timing so no detonation will occur. How will you be screwing yourself over with a stock tune?
Old 08-30-2012, 09:58 PM   #7
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
I believe he's saying since he has the mods, a stock tune would be a step back. Vince will shoot you a nitrous tune without much problem.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 08-30-2012, 11:27 PM   #8
Amarr014
BAD BEE
Amarr014's Avatar
Drives: very fast!
I have a nitrous tune from vince and stock plugs and run a 75 shot no problems... you dont need three tunes or new plugs although new plugs arent a bad idea...
2011 V6 LS M6 | straight piped | HIDs | Injen CAI| 75 Shot NX nitrous|Trifecta Tune|RX ported TB,IM and matched heads, Isolator| RX Catch Can | AAC Red Halos | AAC Red interior lighting | Red bowties | 15% tint | Tinted Tails | SS wheels and tires | SS tips| Cat delete| Arc audio 10's| ******** box|Scosche&kenwood|
Amarr014 is offline   Reply With Quote
Old 08-31-2012, 12:25 AM   #9
2010_camaro
I will have a talk with vince.
Old 08-31-2012, 10:19 AM   #10
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
I run a 100 shot with just Vince's canned tune and stock plugs....
Sent him a datalog from the dyno run, he said everything looked fine.....
I have the nytrex kit
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete |
h2oplay is offline   Reply With Quote
Old 08-31-2012, 11:11 AM   #11
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
You really should have a tune for a 100 shot and up, much less risky. If you lean out...
DarkneSS is offline   Reply With Quote
