05-05-2013, 09:11 AM | #1 |
Drives: 2010 camaro ss Join Date: Mar 2013
Torque spec for header bolts?
Getting ready to do a header install and I need to know the the torque specs. Thanks
05-05-2013, 09:14 AM | #2 |
knows 2 facts about ducks
I posted all the LS3 torque specs in the Big DIY Index. It's a sticky in the DIY subforum.
On that note, I believe it's 18 lbs/ft though. |
05-05-2013, 09:19 AM | #3 |
Drives: pleather and Chiclets Join Date: Mar 2012
remember to retorque after a few heat cycles...the cats or off road pipes too
05-14-2013, 01:31 AM | #4 |
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova Join Date: Aug 2010
I doing my Kooks header install tomorrow and instructions say to torque bolts to 25-30lbs inst thatt too much. I dont want to strip the threads on the head. It also states to use a little bit of hi temp silicone on the gasket on both sides!? Is this correct? Sorry 1st time installing headers,on a car. Just want to make sure i do it right! Also do i use any lock tite on the bolts?
Performance- Kooks Headers w/HF cats, ZL1 Corsa exhaust, VMax, CAI Inc. CAI, MGW shifter, RX CC Suspension - KW V3 Coilovers/ Full PFADT & BMR suspension Appearance - ZL1 Fascia/Sides/ Diffuser, AAC Afterburners, RK Sport 3pc Spoiler, SLP Black out Kit
05-14-2013, 06:12 AM | #5 |
Pretty sure it's 18 but
05-14-2013, 08:08 AM | #6 |
Drives: '11 2SS/RS A6 Join Date: Apr 2011
I just finished installing my Kooks last night. I re-used the factory bolts and torqued them to between 18 - 20 ft lbs. No leaks so far. Will re-check after a few heat cycles.
Do not use loctite; you will never get them off if you have to. Use some anti-seize.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can |
05-14-2013, 08:29 AM | #7 |
ARH told me 18 ft./lbs. on the header bolts, and just "good-n-tight" on the O2 Sensors. That being said, I torqued the bolts down to about 22 ft./lbs. to account for prevailing torque, and I used anti-seize on the bolts too. And yes, need to re-check them in about 500 miles.
05-14-2013, 08:45 AM | #8 |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
Use oem gaskets. Do not use loctite. Anti seize if fine on header bolts but that's up to you. However, you should use it on 02 sensors or pay the price later. 18ft lbs on the bolts then recheck after some cycles.
05-14-2013, 08:57 AM | #9 |
Drives: 2010 2ss LSR CAI, Borla S axle back Join Date: Apr 2011
I installed my kooks LTS about 2 weeks ago did about 25 ft-lbs...my buddy I did the install with is a mechanic and said 25 is fine and should not need retightening but I may still check them and the cats
2010 2SS (Red w/ White Stripes) LSR CAI, Kooks 1 7/8 LTs with Cats, Borla S-type Axle-back Exhaust and Tune
"cmon, the engine has all forged internals...its just begging to be blown" |
05-14-2013, 09:12 AM | #10 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
None of mine loosened up after 500+miles but there are PLENTY reports of that happening. Definitely enough to go back and check. It only takes a 15min or so to check them all.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
05-14-2013, 09:40 AM | #11 |
Drives: 2010 2SS Join Date: Jan 2013
german nice and tight.. 120,000 miles no issues..
05-14-2013, 09:50 AM | #12 |
Drives: 2010 IOM RSS Join Date: May 2009
Kooks calls for 25-30 ft lbs. The manual calls for 18 if I remember right. We do not use the KOOKs gaskets. The stock gaskets seem to work better.
05-14-2013, 10:33 AM | #13 |
Yeah im using my stock gaskets too as my tuner recommended. again Kooks calls for 25-30 lbs so I will be doing 25 lbs and see how that goes. The stock bolts had some yellow stuff on them when I was taking them off last night that's why I asked if I should use locktite but I will just stick to anti seize. Thanks everyone!! Cant wait to see how it will sound after!
05-14-2013, 12:10 PM | #14 | |
Drives: 2010 SS L99 Inferno Orange Join Date: Apr 2012
Should be kooks 25-30 ft lbs!!! |
