09-16-2013, 05:56 AM | #1 |
Drives: White SSRS Convertible Edelbrock SC Join Date: Sep 2009
tops frame lube?
Has anyone ever lubed the joints on the convertibles top frame?
Or is it a good idea? Is it possible to do without getting it on the canvas? |
09-16-2013, 06:58 AM | #2 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
That's a good question. I always wondered that myself when I look at it folding and unfolding.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
09-16-2013, 11:19 AM | #3 |
Drives: 2011 Camaro Convertible SS2/RS LS3 Join Date: Jun 2012
Mine squeaks now and then over bumps, so one day I put the top half way up and sprayed a bit of WD40 on all the joints. Next time I took it for a drive the squeaks were gone. They came back about a month later. So I need to reapply.
PS it doesn't squeak constantly, just when you hit something big, like going over railroad tracks. |
09-16-2013, 07:14 PM | #4 |
My thoughts are that WD would dry the joints out.
I was thinking of something with more lubricating qualities , like white grease. The trick would be not getting it on the interior liner. Maybe vaseline |
09-16-2013, 07:45 PM | #5 | |
Pills are for Pansies
Drives: 2023 2SS Red Hot Vert Camaro Join Date: Jul 2008
09-16-2013, 07:54 PM | #6 |
Drives: 2013 2SS/RS M6 NPP Join Date: Dec 2012
I would think a dry lubricant like graphite would work better.
Google, CRC Dry Grhapite Lube, 10 oz Aerosol can, Black |
09-09-2014, 11:11 PM | #7 | |
Convertible Top Maintenance
I have done a lot of research on this as I have owned several rag tops over the years.
One thing I can assure you, WD40 is a very bad lube. It should really only be used as a cleaner as it actually dissolves grease and only lubes temporarily. Get your self a can of White Lithium grease and make sure to apply it carefully on metal parts only. Here is a video: |
09-10-2014, 11:48 AM | #8 |
GREAT VIDEO thanks for information!!!
will have to get lubricating
09-10-2014, 12:54 PM | #9 |
Drives: 2013 Convertible /2SS/RS/LS3 Join Date: Jul 2011
Thank you sswiss3000
Great video and information for us "topless" guys |
