Old 10-22-2013, 10:07 AM   #1
swisschris104
Drives: 98 Chevy Camaro V6
Overheating at idle.
My car has started to overheat when sitting at stop lights. the needle has not went to far past 220 (middle). Any idea of what this could be? I have a 98 Camaro V6. Also when car starts to overheat the heat starts blowing cold air.. Maybe its a heater core?
swisschris104 is offline   Reply With Quote
Old 10-25-2013, 12:58 AM   #2
MrCool
MrCool's Avatar
Drives: '95 Z28
Your heater core won't cause your car to overheat. Overheating issues are usually caused by (but not limited to) bad radiators, bad ECU/PCM not turning on the fans, bad fan relays, bad fans, etc, etc...
1995 LT1 Z28, "Bright Teal Metallic", Stock
MrCool is offline   Reply With Quote
Old 10-25-2013, 01:08 AM   #3
NoItsOnlyAV6_ButItRocks
Drives: 2010 2LT RS M6 IOM FlwMstr
When the engine is cold check your water in the reservoir and the radiator itself. From what you describe it sounds like you are low on water. Low on water causes the engine to overheat and the cold air is blowing out because the heater core only has no water in the coils so when the fan blows over it all you get is cold air.
NoItsOnlyAV6_ButItRocks is offline   Reply With Quote
Old 10-25-2013, 07:13 AM   #4
dmginc
dmginc's Avatar
Drives: In Circles
replace the thermostat it is stuck open. very simple part to replace usually and cheap.
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
