05-02-2017, 03:10 PM | #1 |
Drives: 2013 camaro ss 1le supercharged Join Date: Apr 2016
dssv struts
will the z28 dssv struts fit on a 2013 1le camaro, or do you need to purchase the whole suspension kit
05-02-2017, 04:54 PM | #2 |
Tri-County Camaro SWFL
Yes, no need to change everything but the more you put Z/28 parts on the more you benefit.
EX: To really benefit from the DSSV you should throw on Z/28 rims and tires or something similar.
05-02-2017, 05:11 PM | #3 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
That's a good question for Dropspeed, he's gone thru a lot of z28 parts. If I remember correctly, there is a point where it becomes too much and you start losing performance
"Make yourself sheep and the wolves will eat you"
05-03-2017, 02:52 PM | #4 |
Drives: 2013 1LE 1SS Victory Red 1 of 76 Join Date: Sep 2008
I have the Z28 struts, springs, and bars with 19"s and RE71R's. Works well for autocross. Be prepared for a pounding on bad roads. I have no problem with it, but I just use it as a weekend warrior. You'll notice much less brake dive and acceleration squat.
2013 1SS 1LE Victory Red. 187 CAM-C
05-10-2017, 08:13 PM | #5 |
Just throw a Z28 over your 1LE... good to go.
05-10-2017, 09:06 PM | #6 |
Drives: Camaro Justice Join Date: Jun 2007
The DSSV struts require the use of Z/28 coils. They are a very good.
For half the cost you can go to Bilstein B6 monotubes and DSE lowering coils and get 90% of the benefits of the Z/28 setup. |
