#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Cosmetic modifications (exterior and interior)
Old 09-16-2017, 11:41 AM   #1
tuckertravis
tuckertravis's Avatar
Drives: 2017 Camaro 2SS
Complete dash removal?
Has anyone taken their whole dash apart? Mines been rattling and thought I had fixed it with some foam. But the rattle is still there. I found on lethals YouTube channel how easy the front leather piece comes out but haven't found anything on the top side being removed. Assuming it's just held together with a bunch of clips but don't want to start prying or pulling without knowing for sure.
tuckertravis is offline   Reply With Quote
Old 09-16-2017, 11:47 AM   #2
jaysonstuart
jaysonstuart's Avatar
Drives: 2016 Camaro 2SS
Why not let the dealer fix the rattle?
I've always feared removing the dash that it will never be the same again after you try to put it back in.
jaysonstuart is offline   Reply With Quote
Old 09-16-2017, 11:49 AM   #3
tuckertravis
Taken vehicles in before for rattles and what not but never had them really fixed at a dealer or they said they can't hear it.
Old 09-16-2017, 12:05 PM   #4
Lemooreace
Drives: 2017 Camaro 2SS, Black/Red
The main dash trim itself is simple. At least then you can peek in. I wouldn't go much further than that. Pull the display, pull the dash piece above the glove box and you'll see the remaining screws. It pops off easy. Be gentle with the dust guard around the steering.
Lemooreace is offline   Reply With Quote
Old 03-24-2024, 10:24 PM   #5
BoredAF
Drives: 2018 Camaro zl1 1le
I tore the entire dash apart and replaced the entire wire harness. Its not that hard.
BoredAF is offline   Reply With Quote
Old 03-25-2024, 11:54 AM   #6
ctrlz
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP
Just out of curiosity, would that also give you access to the A/C evaporator? It's typically a lot of work to replace those things. I have done it (not in a camaro).
ctrlz is offline   Reply With Quote
