03-05-2021, 10:54 PM | #1 |
Drives: 2011 Chevy Camaro LS Join Date: May 2016
Coils/spark plugs
I had a misfire on 1 cylinder and 3. I changed the gasket and all spark plugs .I have a code P2271 currently.
I started my car and I was getting a misfire on cylinder 1 now. So I tried switching it up. I put cylinder one to cylinder 5. That fixed the problem for like a day. Then I was heading to work then it gave me another misfire P0301 which is still cylinder 1. Would it be all coils that I need to replace now or what else could it be? |
03-05-2021, 11:36 PM | #2 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
How many miles? Are you running a catch can? If not, you may need to do an upper induction cleaning on it.
03-06-2021, 08:44 AM | #3 |
Drives: Chevy Silverado Join Date: Jul 2020
Could also be an injector.
03-06-2021, 09:00 AM | #4 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Did you change the wires, particularly when you swapped the coils. The odds on all the coils going out at once are slim.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
03-06-2021, 09:17 PM | #5 |
03-06-2021, 09:18 PM | #6 |
