Old 07-18-2021, 06:57 PM   #1
dma05
dma05's Avatar
Drives: 2011 Camaro 2SS/RS
Oops! New radiator or???
I was installing a harness and I accidentally put too much pressure on this hose (eval hose?). The plastic nipple broke. My question is do I need to replace the radiator now or can I use some Gorilla Glue or JB Weld to re-attach it?
Thanks
Allen
2011 Camaro 2SS/RS
dma05 is offline   Reply With Quote
Old 07-18-2021, 07:06 PM   #2
G8One2
Drives: 2014 Camaro 2SS
If it were me, I'd replace the radiator. Gluing that on will likely be nothing but problems.
G8One2 is offline   Reply With Quote
Old 07-18-2021, 07:07 PM   #3
G8One2
You "might" be able to thread a 1/4" npt hose barb into the radiator if you wanted to try and repair it.
Old 07-18-2021, 07:22 PM   #4
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
^^^^THIS^^^^
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 07-18-2021, 09:35 PM   #5
dma05
dma05's Avatar
I went to Lowes and got that fitting, but there isn’t enough room to drill and tap the threads. Looks like a new radiator 😡
Allen
2011 Camaro 2SS/RS
Old 07-19-2021, 07:45 AM   #6
gtstorey
1/8 npt might work
Old 07-19-2021, 09:47 AM   #7
Pearlj10
Drives: 2011 Camaro 2LT
I have a V6 and the drain peacock was stripped out. So after much searching, I went with the C&R all aluminum radiator. They used to supply most of the NASCAR folks and so far I’m happy. Hard to beat purchasing what was a $1k radiator for $225. They’re trying to get rid of old stock, thus the pricing.
https://www.crracing.com/product/che...8-oe-fit-w-toc
Pearlj10 is offline   Reply With Quote
Old 07-19-2021, 06:46 PM   #8
redrum_maro
Runs on caffeine
redrum_maro's Avatar
This seems really great. I'll have to look more into them
redrum_maro is offline   Reply With Quote
Old 07-20-2021, 02:03 AM   #9
dma05
dma05's Avatar
I already purchased an OEM radiator. Going to install it this weekend. BUT, I did find this video and may try it on my broken radiator to keep it as a backup.
https://youtu.be/LhlvgD9Qxlk
Thanks!
Allen
2011 Camaro 2SS/RS
Old 07-25-2021, 04:20 PM   #10
Speeddmn
Drives: Chevy Silverado
I did the same thing, only i broke mine installing my fans... ordered an oem off amazon for under 100.
Speeddmn is offline   Reply With Quote
Old 07-25-2021, 08:56 PM   #11
dma05
dma05's Avatar
I just got my new one installed today. Took about 4 hours due to some of the Heartbeat Supercharger reservoir/hoses in the way.
Allen
2011 Camaro 2SS/RS
Old 07-28-2021, 08:42 AM   #12
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
I would try and repair it first.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
