06-12-2020, 08:09 AM | #1 |
Drives: Chevrolet Camaro Join Date: Mar 2020
Throttle Controller
So I'm looking for some information on throttle controllers. Who has them what type do you like it. I'll take any advice from y'all
Thanks Sent from my moto g(7) power using Tapatalk
06-12-2020, 12:08 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
I have the Vitesse and love it! Some people have complained about it giving them the "reduced power" state but I've only had this happen once in ~4 years and it was when I flicked the throttle a couple of times quickly (I'm guessing the ECU can't keep up/gets confused with the voltage amplification from the throttle controller).
06-12-2020, 12:38 PM | #3 |
Great White
I have Vitesse now for 2 years.. not a single issue and love it. Others have said otherwise but no issues with mine.
06-12-2020, 12:41 PM | #4 |
Same. Never have had an issue and I run mine with a ported TB.
06-12-2020, 07:58 PM | #5 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
took mine out of my wrecked ls3 car and put it in the l99. i think it actually works better in the l99 as in more noticeable from sp 4 and up,i noticed it changes the shifting considerably. like everyone else i have seen horror stories mine messed up twice in the ls3 car but i just pulled over unplugged it at the petal and plugged it back in later.i didn't think it was that much of a inconvenience for the effect it has the 99.9% of the time that it works.
06-12-2020, 09:07 PM | #6 |
It don’t come easy.
Here’s a list I made up awhile ago.
Throttle Controllers I personally have the Pedal Commander. No issues to date and fun to drive with it.
06-13-2020, 04:21 PM | #7 |
old school chevy rodder
Btw the " Vitesse" when it came out looked exactly like any other Chinese controller with a sticker on it BTW....
06-13-2020, 06:26 PM | #8 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Camaro6 forum members praise the solar performance ones. I’ve never used one before so I can’t comment
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
06-13-2020, 06:52 PM | #9 |
It don’t come easy.
I’ll add it to the list.
06-13-2020, 07:33 PM | #10 |
Drives: 2011 2SS RS Join Date: Apr 2015
Pedal Commander. Works great, no problems. The bluetooth version is the best.
06-13-2020, 08:39 PM | #11 |
vitesse. Had it about four years. The original one i had before that threw a code and they replaced it. No trouble since.
06-14-2020, 01:17 AM | #12 |
What is the bluetooth for? Change settings using your phone?
06-14-2020, 05:06 AM | #13 |
It don’t come easy.
That’s basically it. Allows you to hide the button controller under the dash or wherever, as well.
06-14-2020, 02:47 PM | #14 |
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert Join Date: Sep 2019
I have a vitesse for sale if you decide to go that way. $100. In the interest of full disclosure, it worked great for about 2 months and then one day my car went into limp mode. I took it off that day.
