02-10-2020, 11:36 AM | #1 |
GM OEM Dark Tail Lights vs Amazon ATOPLITE Brand
Alright, this is just a quick little comparison of the GM OEM Dark Tail Lights vs ATOPLITE brand from Amazon.
First thing first. The ATOPLITE brand looks to be a great product for a very fair price, so if you're working on a budget this is not a bad way to go. You can also buy just the tail lamps, 3rd brake light, or a complete kit that comes with the tail lamps, 3rd brake light, and dark reflectors. Cost: GM OEM Tail Lights - $450-$475 depending on where you buy from. GM OEM 3rd Brake Light - $100-$125 depending on where you buy from. Aftermarket Dark Rear Reflectors - $20-30 depending on where you buy from and brand. Total cost for full rear end darkening: $570-$630 ATOPLITE Tail Lights ONLY - $305 ATOPLITE 3rd Brake Light ONLY - $59.50 ATOPLIGHT Kit (Tail Lights, 3rd Brake Light, Rear Reflectors) - $359.50 Total cost for full rear end darkening: $359.50 Packaging: Packaging from both was very well done, no complaints here. GM Packaging: ATOPLITE Packaging: Fitment: Fitment was identical, lens quality was comparable to the OEM, and overall quality was pretty close. The lens on the ATOPLITE 3rd brake light, is actually noticeably darker than the GM OEM, can be seen in the picture below, the light on the left is the ATOPLITE brand, and the right is GM OEM. Lighting: Without having the ATOPLITE brand side by side with the GM OEM Lights you probably wouldn't notice the difference in lighting, but the ATOPLIGHT brand is noticeable less bright(DRLS) Brake light intensity was similar, but the GM OEM still took the win on brightness. Below is a picture I snapped of my install. Keep in mind that the tail light on the driver side is the OEM GM Lights, and the passenger side is the ATOPLITE brand. Notice in the picture how on the ATOPLITE brand light, you can see some light coming just to the left of the light, that is actually the one thing I noticed that i did not like about them, there is a small gap near the end of the housing, where that bit of red light came shining through, very noticeable compared to the GM OEM not allowing any extra light where it doesn't belong.
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust |
02-10-2020, 12:02 PM | #2 |
Drives: 17 camaro ss Join Date: Mar 2018
Hopefully it's just the angle of the picture, but the light on the right seems to cut out part way across?
02-10-2020, 12:19 PM | #3 | |
Just the angle, the light does not cut out. Sent from my iPhone using Tapatalk
Modifications
02-10-2020, 06:31 PM | #4 |
Drives: 2017 Camaro 2SS A8 Join Date: May 2019
Detailed and brief! Good job Tricksta. This will be helpful for everyone looking to make this type of purchase.
Roto-Fab w/sound tube delete, Katech ported TB, Pray IM, Velossa, DD side markers, DSX FF, UPR Catch can, Halo brace, My custom vent gauge pod
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ |
02-10-2020, 06:40 PM | #5 | |
The ATOPLITE brand is definitely well worth the ~$200 savings if you are on a budget, but if you are very picky and detail oriented and want perfection like me, OEM is the way to go.
Modifications
02-11-2020, 11:08 AM | #6 |
Drives: Turbo 6.2 Join Date: Feb 2019
Great thread. Thanks
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
02-11-2020, 12:04 PM | #7 |
Drives: 2017 2LT RS Join Date: Nov 2018
Here is mine, with sequential turn signal.
250 USD on Aliexpress. |
02-11-2020, 02:54 PM | #8 |
Modifications
02-11-2020, 08:55 PM | #9 |
They don't look terrible, just not a fan of the sequential effect.. Do the bottom "eyebrow" not light up as DRL's on those?
Modifications
02-11-2020, 11:35 PM | #10 |
Eyebrow is ok.
02-12-2020, 08:13 AM | #11 |
Drives: 2022 Camaro 1SS Redline Join Date: Nov 2019
Great thread, nicely done write up.
2022 Camaro 1SS A10 Black, Redline Edition - SOLD
02-12-2020, 05:18 PM | #12 |
Modifications
02-16-2020, 05:07 PM | #13 |
Drives: 18 2SS 1LE NFG Join Date: Aug 2018
I had summit credit and summit gift cards and summit is 10 minutes from the house so I bit the bullet and went with the gm smoked lights. I am amazed how much these change the car, I need the third brake light now. Either either one will look better than the stock ugly ass red
02-16-2020, 10:14 PM | #14 | |
The dark lights definitely instantly increase the looks. Sent from my iPhone using Tapatalk
Modifications
