Old 12-11-2017, 10:01 AM   #1
ramil13
ramil13's Avatar
Drives: 2015 Chevrolet Camaro 2LT RS
Fabberge Twin Turbo Kit Gone?
I can't find the kit on eBay or any website anymore. Is it completely gone? Because that's the best setup with a methanol kit I've seen so far. Rather get that than a supercharger.
K&N intake, Custom Tune, Billet Catch Can, K.C's Ported 72mm TB & IM, Jacfab IM Spacer, Primary/Secondary Cat & Muffler Delete, Magnaflow Xpipe, 2.5" Straightpiped, GM Strut Tower Brace, Mace Engineering Cams, Solo Performance J pipes, Magnaflow Resonators x 2
340rwhp Dyno
ramil13 is offline   Reply With Quote
Old 12-11-2017, 10:53 AM   #2
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Did you Try Face Book. Pretty sure the link they had here took you to Facebook .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 12-11-2017, 12:48 PM   #3
willoverkill
willoverkill's Avatar
Drives: Fast
The Overkill Vortech supercharger is the only bolt on FI kit on the market. You can have turbos made but it'll be custom and cost more than our supercharger kit, and take longer than the 6-8 hours of spinning bolts to install.
For Canadian buyers, Overkill it would ship from me here in British Columbia, no import taxes to pay. Keep us in mind!
willoverkill is offline   Reply With Quote
Old 12-11-2017, 02:38 PM   #4
SDTWDirect
SDTWDirect's Avatar
Drives: Highly Modified
AFAIK, Fabberge is no longer in business. I know this from another platform that they used to deal with (that I am active with)
-AL of SDTW Direct
SDTWDirect is offline   Reply With Quote
Old 12-13-2017, 11:21 AM   #5
ramil13
ramil13's Avatar
Guess I'll be getting a custom made twin turbo then. Supercharger is nice but I want more than just 320rwhp
340rwhp Dyno
Old 12-13-2017, 11:39 AM   #6
djcolopi
djcolopi's Avatar
Drives: @orange_maro
Overkill supercharger stage 3 will get you around 500rwhp, which is around the limits of the HPFP anyways.
Instagram @orange_maro_
djcolopi is offline   Reply With Quote
Old 12-13-2017, 02:20 PM   #7
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
And if you get super technical and grab the LF4 HPFP and whatever else you need to make it work (Ferrari lash cap I think?) you kinda remove that limit too and then in theory you can just go until you run out of supercharger.
DSX_Camaro is offline   Reply With Quote
Old 12-13-2017, 02:49 PM   #8
djcolopi
djcolopi's Avatar
LF4 HPFP has no benefit; no increase in flow rate. Alan jus put down 544rwhp and 500ft*lbs tq on stock hpfp and no supplemental fuel. They ground his cams and modified the fuel lobe, shich increased the flow rate by 15%.
Old 12-13-2017, 08:54 PM   #9
Kenny Camaro
Drives: 2013 1LT RS Camaro
320? E-85 , full bolt on, Overkill tune and a friendly dyno and you can get that with normal aspiration.
Kenny Camaro is offline   Reply With Quote
Old 12-14-2017, 10:12 AM   #10
ramil13
ramil13's Avatar
Great, probably will get the stage 3 then i like whines more anyways. What's HPFP.... forged pistons? Rebuilding the internals of the engine right?
340rwhp Dyno
Old 12-14-2017, 10:21 AM   #11
imaSSnake
'Maro
imaSSnake's Avatar
Drives: 2015 SS 6.2L Auto 2SS
High pressure fuel pump
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
imaSSnake is offline   Reply With Quote
Old 12-14-2017, 11:27 AM   #12
ramil13
ramil13's Avatar
Anyone know at what point you'll have to rebuild the engine to handle the power? At 800 HP?
340rwhp Dyno
Old 12-14-2017, 10:07 PM   #13
gringo
gringo's Avatar
Drives: Camaro V6
800 hp? You're pushing it with these engines at stage 2.
gringo is offline   Reply With Quote
Old 12-14-2017, 10:39 PM   #14
djcolopi
djcolopi's Avatar
No, the only limit is the HPFP. We have two guys over 700rwhp (850-940hp) one spraying nitrous on his turbo setup and I am not. Now granted built short block with stock cams and 6L50E. However, I made 510rwhp (637hp) on stock bottom end. You will need to build the short block and either use meth, supplemental fuel or get a custom hpfp made to make 800hp, but we have a few people pushing the build.
