04-07-2022, 08:07 PM | #1 |
Intake manifold
I’m replacing my intake manifold with a Edelbrock intake,so,some of the engine builders,what do you use on the intake ports,and the China walls for a sealant.
04-08-2022, 08:43 AM | #2 |
What are China walls?? lol. I just used the OEM gasket set for my LOD...
04-08-2022, 01:49 PM | #3 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Should be cut for the same runner gaskets your oem intake manifold uses
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
04-08-2022, 01:57 PM | #4 |
For anyone that doesnt know what China walls are - that's where the intake manifold meets the wet lifter valley on old school small/big blocks, thus requiring a thick silicone bead on the front and rear of the block for sealing between it and the intake.
You are speaking old school terms here man. Looks like you have a LLT V6? Which intake you looking at? You make sure to find something compatible for your engine? IDK if LFX/LLT engines even have china walls, pretty sure they don't. I know our V8s don't, as the LS engine intakes don't touch anything wet and use O-ring gaskets for the intake ports. Pretty sure it's the same for the LLT/LFX.
04-08-2022, 08:40 PM | #5 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
Even though this is a British replacement part it can also be used on Chevrolets and other American or otherwise vehicles. In some cases can be used on engines.
04-08-2022, 09:35 PM | #6 |
Yea,old school,no I bought a 1981 corvette 2 months ago,so I was asking about it.
04-09-2022, 05:10 AM | #7 |
man, I'm old school and never hear of that phrase at all..
Either way I used Felpro gaskets on the intake ports and a thick bead of whatever was the best Permatex silicone back then. Was silver in color, thats all I remember.. lol
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
04-10-2022, 09:26 AM | #8 |
^^^ This. I to have never heard that term back in the day when I did manifold swaps and such. Always used Felpro and black permatex as well.. Thanks InFiD3ViL for the translation sir.
04-10-2022, 10:40 PM | #9 |
Drives: 2010 CAMARO RS/SS Join Date: Jul 2021
Ahhhh i learn something everyday here, so China walls not what i was thinking....
