02-28-2013, 04:45 PM | #1 |
Drives: 2011 Camaro SS L99 Join Date: Jan 2012
Another Hurst Roll Control (line lock) problem
Finally got all the right parts from Hurst and had a shop tie the solenoid in to the master cylinder. The line lock works as it is supposed to, but the Brake Control Module thinks there is a problem when I engage it and throws a "service stabilitrak" message, and you cannot turn traction control and stabilitrak back on until you clear the BCM with a scanner.
Question? Has anyone else experienced this problem, and/or knows how to keep it from happening? Any help will be appreciated. Thanks, Jeff |
02-28-2013, 05:43 PM | #2 |
Drives: SLOW. Join Date: Feb 2013
yup, we have a solution to this. we have done many line lock installs on 5th gen's. pm me if you have any questions ill sort it out for you.
-mike |
02-28-2013, 06:02 PM | #3 |
just shot you a pm back, hope that helps man. Let me know how it works out for you.
02-28-2013, 07:22 PM | #4 |
Yep, I have the same issue. I drive the car a little, then shut it off and when I start it back up the message is off.
02-28-2013, 08:51 PM | #5 | |
However, if you have a solution don't let this stop you from posting it. Thanks, Jeff |
03-01-2013, 10:28 AM | #6 |
Jeff
Drives: 2010 Camaro SS/RS Join Date: Feb 2010
Can you pm me also on the fix. Thanks.
03-02-2013, 08:14 AM | #7 |
Most hated in NM....
Drives: Sold the 6POINT2, went to a 50THZ06 Join Date: Sep 2011
Yep, message turns on for me so after the pass I turn the car off and next run it's off again. Doesn't seem to effect anything during the run but I don't think I would drive on the streets very far with that lights on.
I actually use the light to tell me the line-lock is working before I get to the line. I hit the linelock button in staging and release to see if the lights come on. This also turns off all the nannies so I don't have to hold the T/C button down.
03-02-2013, 09:10 AM | #8 | |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
I'm guessing this takes a little programming to make it work? |
03-02-2013, 10:25 AM | #9 | |
Thanks guys. |
05-29-2014, 03:47 PM | #10 |
Drives: 2010 Camaro SS2 DeadBLK Join Date: Nov 2010
can you pm the overide solution for the stabilitrack when launching my L99 with the hurst roll control unit?
05-29-2014, 05:24 PM | #11 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
I pull out a couple of relays and turn all the nannie's off when I'm at track. Same thing with the TCI line lock. I believe it's fuse #40 and relay #43 and that turns off the ABS, but you will get an audible warning when you start it up, but it goes away. Think about it your front wheels are locked and the rear wheels are spinning, computer does not like that.
05-29-2014, 08:18 PM | #12 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
Hey guys that good to know am putting a line lock on now.
Hey jbrown we did to meet at the track soon again.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
05-29-2014, 09:38 PM | #13 |
05-30-2014, 04:34 PM | #14 |
Am going to try next Friday the 6th its TnT that night. May not have the line lock on by then. Work has picked up been working on two trucks and a tractor. I also had the front off the car working on some other things need to see if it help or not will see.
