06-18-2020, 06:54 PM | #1 |
Drives: 15 Camaro SS Join Date: Oct 2018
Question on cam with an up coming FI build
So i did the GPI max kit this past winter along with a bunch of other things. Love the cam. Question is how bad would this max cam be for a blower? Ill be throwing a blower on this next winter and curious how bad it would hurt me to keep it the way it is. Love this cam right now
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
06-18-2020, 07:13 PM | #2 |
06-18-2020, 10:42 PM | #3 |
Drives: 2010 1SS LS3 Join Date: Aug 2019
Big centri would eat that cam up.
2010 CGM 1SS
408/4L80E/ZL1 ESS G4 |
06-19-2020, 06:22 AM | #4 |
Centri is what I'm planning on running. Pretty much the same kit you are running
06-19-2020, 06:42 AM | #5 |
GPI Sales Consultant
Like Big Biscuits said, that'll play nice with a centrifugal. With a PD blower you wouldn't pair to something with so much overlaps, but centri's work nice with big NA cams. That's gonna be a rowdy setup!
Got a question about a GPI product? Feel free to shoot me a message! |
06-19-2020, 07:26 AM | #6 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Send it! I have 233/248 with my centri. Runs great besides my hot starts and belt slippage.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
06-19-2020, 10:04 AM | #7 |
Hot start should be fix-able with proper tuning. Belt slip requires a mechanical solution.
06-19-2020, 02:57 PM | #8 |
Fantastic to hear and on a side note, i couldnt be happier with you guys. The GPI team from top to bottom was extremely polite and helpful. Thanks again!!
06-19-2020, 04:44 PM | #9 |
Drives: it changes Join Date: Nov 2010
If you love it, then use use it.
06-21-2020, 04:47 PM | #10 |
Glad to have awesome customers like you!
06-22-2020, 10:04 PM | #11 |
Let me get some dyno numbers and I will sell you my kit. Not that I don’t like it, just have some different parts in the garage that need to be tested.
2010 CGM 1SS
06-23-2020, 07:53 AM | #12 |
Big Biscuits - if you end up selling that kit, give me a shout. Definitely looking at some options for centri's and I like a lot of stuff ESS does with their kit.
06-23-2020, 08:49 AM | #13 |
Will do. I have a agp twin kit that I bought cheap and am itching to try it out. I want some hard data on how this kit performs with hp/tq numbers to back it up before I take it off. So far it’s a beast, and wastegating a centri does just what I thought it would.
2010 CGM 1SS
06-23-2020, 10:02 AM | #14 | |
