01-07-2020, 09:44 PM | #1 |
Drives: 2015 camaro 1le 2ss Join Date: Dec 2019
SHIFT KNOB
hey guys been trying to find a DIY for replacing the shift knob on my 14 1LE.
I love the stock one however the suede is torn. would like a stock replacement but open to other options as well.. thanks in advance.
2014 1LE 2SS CAMARO/STOCK FOR NOW
1973 C/10/5.3/LSA/FTI TH400/ 2004 SILVERADO 4D/4X4/FBO/ |
01-07-2020, 09:51 PM | #2 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Put your hand around chrome ring turn counter clock wise and it will then drop. There is an Allen screw holding it on. There also YouTube videos replacing shift knob.
https://youtu.be/BSshZnKZk6M Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
01-07-2020, 11:15 PM | #3 |
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi Join Date: Apr 2009
01-08-2020, 06:44 AM | #4 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
A little more complicated operation, but in the end very pleasant and for me more accurate than a ball.
01-08-2020, 01:07 PM | #5 |
Tri-County Camaro SWFL
I replaced my entire assembly with an MGW.
https://www.gen5diy.com/collections/...hift-knob-boot or go through your GM parts dept. MGW install instructions but shows how to remove the knob https://youtu.be/iR45CGOnQOo
01-12-2020, 11:56 AM | #6 |
Drives: Subaru Join Date: Oct 2008
What he said.....MGW is the best!
Time for a new ride soon....6th Gen or 5th Gen Z28? Hmmm....
01-12-2020, 03:10 PM | #7 |
02-06-2020, 01:19 PM | #8 |
Drives: 2013 Summit White 2SS/1LE Join Date: Jul 2018
Not sure if you found a shift knob yet, but my factory one was in the same boat as yours, so I found this classic one from Speed Dawg.
It was easy to install and I think it looks great for the price. One 'hiccup' was that initially it started rattling about a month after install. Turns out, the inner bore of the knob's mounting sleeve is slightly too large a tolerance to really snugly fit the shifter shaft (at least mine was-- maybe mine was an anomaly). Anyway, I pulled it off and put a thin layer of RTV black on the shifter shaft (up in the part this is not visible from the outside). Problem solved. Feels and looks great! https://www.speeddawg.com/camaro-1le...shift-pattern/ Last edited by CHRISCAM; 02-06-2020 at 01:20 PM. Reason: Link to page did not appear in my reply |
02-09-2020, 01:31 PM | #9 |
Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
Love my MGW!
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
02-09-2020, 04:27 PM | #10 |
EPCO makes custom ones with endless options.. dream it and they probably will make it for you. Very reasonable price to. I know a bunch of people who have EPCO shifters and all very happy. I’ve seen some pretty awesome ones out there on people’s rides.
I wanted something with a new school and old school combo... I had them do a custom Hurst ball shift knob for me. Feels better to than the stock 1LE one did.
Car mods: never enough!
02-09-2020, 04:29 PM | #11 |
02-14-2020, 08:58 AM | #12 |
2016 2SS Convertible
That looks really nice! Did you need an adapter? The knob doesn't really screw on our shifters, did you get non threaded?
02-14-2020, 09:35 AM | #13 |
Non threaded i believe on the gen5's. Its been awhile since messing around with the shifter's, so i cant fully remember. EPCO has made thousands for all makes and models though. They would know if you spoke to them. I do know i ordered the black extension adapter thing so the fabric was a little lower and not right at the base of the ball and that has 1 or 2 set screws. The ball part of the shiftier at the base has 3 set screws on mine. Check out EPCO site and then call them. They really make some amazing custom stuff.
02-21-2020, 09:00 PM | #14 |
Drives: Chevy Camaro SS 1Le Join Date: Feb 2020
MGW
Best . Nice and tight shifts !
