Old 02-20-2021, 11:26 PM   #1
BigRockerL99
Drives: Chevrolet Camaro Ss
Quad tip Rear Diffuser
Does anyone know where I can get a hood rear diffuser for quad tips without breaking the bank? Iíve seen duraflex but have heard bad things about them. Thanks.
BigRockerL99 is offline   Reply With Quote
Old 02-21-2021, 04:30 AM   #2
CPCNY
CPCNY's Avatar
Drives: 2010 2SS/RS, VR ext/Blk Int
https://www.summitracing.com/int/par...illocation=int
This is what I used. $145 and free shipping.
CPCNY is online now   Reply With Quote
Old 02-21-2021, 07:22 AM   #3
KillboyPowerhead
Drives: 2015 Z/22
You could try the dealership for the factory NPP one if you like it. I got mine for $130 CAD at my dealer, cheaper than anything else out there, plus no shipping, just went and picked it up.
Overkill Tuned; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 02-21-2021, 09:37 AM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Depending on what year you are looking for, you could use the ZL1 diffuser as well. There are no aftermarket ones out there that won't kill your wallet, or are duraflex crap, I already looked. lol. I have the 1LE one on my Camaro..
TSP STAGE 3 CAM,231/246 @112 LSA 614/641 LIFT, CIRCLE D 5C-4200 CONVERTER,LOD INTAKE.CORSA EXHAUST. 486RWTQ/475RWHP.LOTS MORE.
Old 02-21-2021, 05:10 PM   #5
BigRockerL99
Does summit have any for the 2014-15 Camaro ?
Old 02-21-2021, 06:24 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Summit doesn't have one. But there is this..
https://www.ebay.com/i/182395590806
and this.
https://www.amazon.com/Camaro-Hardco.../dp/B07KBH1674
Old 02-21-2021, 07:33 PM   #7
BuddyLee
BuddyLee's Avatar
Drives: 2013 Camaro 2SS/RS
My understanding has always been that the extra piping would add more weight with little to no performance gain. But if weight is added then performance is lost? Do the quad pipes change the exhaust note as well?
BuddyLee is offline   Reply With Quote
Old 02-22-2021, 08:38 AM   #8
the85darkknight
Drives: 2012 Camaro 2LT RS
The choice of tips are merely cosmetic. Everything before is what impacts the exhaust note. I just happen to like the look of quad tips. Like others on here, I picked up that 1LE diffuser for the rear bumper.
IG: StarSaber85
the85darkknight is offline   Reply With Quote
Old 02-22-2021, 09:34 AM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
There is actually no extra piping on a quad setup. Everything from the mufflers forward is the same on all the catbacks, the only difference is the backside of the muffler where the tips are located, there are 2 outlets instead of 1 on each muffler. As for changing the sound, nah... No difference.
Old 02-22-2021, 02:32 PM   #10
Maharam
Drives: 2014 Camaro
Z28 Spring Edition, I got mine cheap used but it was painted yellow
Maharam is offline   Reply With Quote
Old 02-25-2021, 10:16 PM   #11
General Tsouís Chicken
General Tsouís Chicken's Avatar
Drives: Chevy Camaro
I went Ikon.
General Tsouís Chicken is offline   Reply With Quote
Old 02-28-2021, 11:10 AM   #12
Camaro2ss6speed
Drives: Chevrolet Camaro 2ss
I bought the one thatís not zl1 diffuser as that one requires more parts just bought the 1le diffuser bolts right up to our ss and used 4 inch quad tips and removed the silencers!
Camaro2ss6speed is offline   Reply With Quote
Old 03-01-2021, 01:30 PM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^^^ exactly what I have..
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
