Jason 98 TA
Old 09-27-2012, 10:30 PM   #1
Forte
Forte's Avatar
Drives: 2011 2LT/RS CGM W/ Black Stripes
Amp/sub problem
Hey all,
I got my hifonics Brutus 1200 mono amp and two pioneer champion series subs installed about two weeks ago and it has been amazing
Yesterday night while driving home from work I noticed the subs weren't working. I checked and the amp wasn't in protect mode and it was receiving power. I checked connections and all seemed fine. I taped a fuss and suddenly it worked again.
This morning it again wasn't working but amp was again under power but no sound. Got to work and messed with connections. Touched left input cable and it kicked on again. Leaving work it again wasn't on but couldn't get them to pop back on.
Any idea what in the world could be happening? Oh, normally when I shut car off a couple seconds later there's a small thud from subs and amp light kicks off but now no thud just light kickin off of amp..
Forte is offline   Reply With Quote
Old 09-28-2012, 07:20 AM   #2
mgoodbar
White 2ss, LT, CAI, Tune
Drives: 2010 L99
sounds like ya need to go through all the connection and tighten everything up, did you have someone install all of it?? If so i would take it back to them. the fuse thing is kinds scary though, that sounds like a broke solder/weld on the circut board maybe???
If you have a ohm meeter check your speakers to to make sure they are ok...
mgoodbar is offline   Reply With Quote
Old 09-28-2012, 08:57 AM   #3
vtxretro02
vtxretro02's Avatar
Drives: 2012 Camaro 2ss Heritage Grill/GFX
Check you battery voltage with a multimeter and all connections on your battery. A bad or loose ground on your battery or amp grounding will manifest many odd. Issues that truly may not be the cause.
vtxretro02 is offline   Reply With Quote
Old 09-28-2012, 09:02 AM   #4
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
appears your bass is knocking connections loose.. and the power off 'thud' from the amp can be resolved by connecting a relay.
Old 09-28-2012, 09:07 AM   #5
metthem
metthem's Avatar
Drives: 2011 LS
or a bad rca plug
Trifecta tune, CAI intake, ADM Race Scoop, Doug Thorley Shorties, Solo High Flow Cats, Magnaflow resonated X-pipe, Flowmaster AMT axle back, Gary's custom front bowtie, rear bowtie delete, tinted windows, headlights, and taillights, debadged fenders, gunmetal gills, gunmetal tailgate (CAMARO)
metthem is offline   Reply With Quote
Old 09-28-2012, 09:26 AM   #6
ecko04
Drives: Too many to list
Originally Posted by metthem View Post
or a bad rca plug
I concur. Sounds more like a faulty set of RCAs than anything else.
ecko04 is offline   Reply With Quote
Old 09-28-2012, 01:13 PM   #7
Forte
Forte's Avatar
Awesome thanks for the advice! I will check out the RCA cable first.
I wasn't worried about the thud when i turn it off, but i noticed that ever since the subs haven't been working the thud doesn't happen anymore at all which tells me signal isn't getting to the subs but that the amp is receiving power.
I'll update when i check that out after work!
Old 09-28-2012, 09:54 PM   #8
Forte
Forte's Avatar
The installer tried different subs and different RCA inputs, didn't work. Said the amp was faulty :(
Old 09-29-2012, 05:17 AM   #9
mgoodbar
Drives: 2010 L99
KEEP THE AMP KEEP THE AMP. RCA jacks need soldered back in pice of cake. .... I bet there is a fine line crack on the input jacks were they connect to the board.....
Old 09-29-2012, 02:07 PM   #10
Forte
Forte's Avatar
Um... What? Lol I'm a n00b to this stuff
Old 09-29-2012, 02:34 PM   #11
DangerZL1
Drives: Future ZL1 Owner
He's saying the amp can easily be repaired rather than purchase a new one. Isn't it under warranty or has it already been replaced?
DangerZL1 is offline   Reply With Quote
Old 09-29-2012, 02:50 PM   #12
Forte
Forte's Avatar
It's under a year warranty I think. The amazon 30 day return policy just passed sadly. Hm... Never done any soldering how hard does this sound like it will be?
Old 10-02-2012, 06:20 AM   #13
ecko04
Did you buy it from Amazon or was it a seller on Amazon? In either case try contacting them and letting them know your amp is defective...maybe they'll help you out. Most manufacturer warranties will be void if you purchase from an unauthorized dealer... Amazon sellers are almost always unauthorized. However, many offer their own in-house warranties. It's worth a shot.
