12-23-2019, 11:49 AM | #1 |
Drives: 2014 Camaro RS convertible Join Date: Mar 2019
MRT V2.0 exhaust black residue
Put an MRT v2.0 axle back exhaust on my 2014 RS convertible and the new exhaust is leaving a black residue above the exhaust outlet on the gray plastic. Anyone else have this? It may be because the tips sit in a little bit farther than stock. Just wondering if anyone else experienced this and what you did to resolve it. Thanks
12-28-2019, 05:59 PM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Direct injection vehicles are just kinda sooty. It gets worse if you have high flow or no cats but otherwise it just kinda does it.
