02-28-2020, 10:12 PM | #1 |
Drives: 2010 Chevrolet Camaro v6 Join Date: Feb 2020
2010 v6 camaro 6 speed fuel pressure
Hey just wondering what my fuel pressure should be at my code reader is reading 455 psi I have a v6 with a dual magna flow exhaust and k&n cai
02-29-2020, 09:46 AM | #2 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
Engine idling at normal operating temperature, the Fuel Pump Flow Control Module Fuel Pressure Sensor parameter should read between 300–400 kPa (43–58 psi). This is stock parameters.
03-13-2020, 03:53 AM | #3 |
Drives: 2011 RS Join Date: Feb 2016
Depends on if you are before or after the high pressure fuel pump
03-13-2020, 10:07 AM | #4 | |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
If he's at 455# before the HPFP I think he has other problems to worry about lol
